嗨吉吉,
我的应用使用两个绝缘电流传感器。在此配置中,STMCWB不允许我进入最大占空比(控制级 - >模拟输入 - >相电流反馈 - >最大调制)。逆变器MOSFET驱动器使用高侧自举,这要求我限制最大占空比,否则失速的电机可能导致高侧栅极电压不足。由于二极管自举是提供浮动高端驱动器电源的最常见方式,因此几乎所有功率级都需要占空比限制。然而,STMCWB使这个领域变灰并迫使其达到100%。我目前通过在右侧头文件中手动覆盖设置来帮助自己(例如#define MAX_MODULAtiON_95_PER_CENT),希望这具有所需的效果。 如果可以在所有配置中将此值更改为可更改的STMCWB,那将会很棒。 问候 坦率 以上来自于谷歌翻译 以下为原文 Hi Gigi, my application uses two insulated current sensors. In this configuration, STMCWB does not allow me to enter the maximum duty cycle (Control stage -> Analog inputs -> Phase current feedback -> Maximum modulation). The inverter MOSFET drivers use high side bootstrapping, which requires me to limit the maximum duty cycle, otherwise a stalled motor could cause insufficient high side gate voltage. As diode bootstrapping is the most common way to provide floating high side driver supply, almost all power stages will require duty cycle limitation. However, STMCWB grays out this field and forces it to 100%. I currently help myself by overwriting the setting manually in the right header file (e.g. #define MAX_MODULATION_95_PER_CENT), hoping this has the desired effect. It would be great if this value could be made changeable STMCWB in all configurations. Regards Frank |
Ciao Frank
感谢您的feedbak,我们可以考虑一下。 是的,您使用的解决方法是正确的。我可以添加anoter trip:尝试使用自定义模板文件进行工作台。您只需在工作文件夹中复制 working templates_040000 PMSM 中的默认模板文件,然后使用记事本修改它,并将WB设置为使用修改后的版本Option-> Template文件夹。 通过这个技巧,您可以节省大量时间。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Frank Thank for your feedbak, we can think about it. Yes, the workaround that you are using is correct. I can add just anoter trip: try to use a customize template file for workbench. You can simply copy in a working folder the default templates file present in the workingtemplates_040000PMSM modify it with the notepad and set the WB to use the modified version Option->Template folder. With this trick you can save a lot of time. Ciao Gigi |
谢谢Gigi,不值得,非常乐于助人!
亲切的问候 坦率 以上来自于谷歌翻译 以下为原文 thanks Gigi, undestand and very helpful! Kind Regards Frank |
2882 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3711 浏览 6 评论
6125 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 21:59 , Processed in 0.895175 second(s), Total 44, Slave 39 queries .
