嗨,我尝试使用命令SCPI配置S21测量的Gdelay格式的每格的比例(以纳秒为单位):DISP:WIND:TRAC1:Y:PDIV 1.0E-9但是我有这个错误:-222:值1.5
E-08被剪裁到最小值0.01。 我想我需要更换仪器上的比例单位,但我没有在文档中找到相应的功能!! 我试图在我的命令中指定单位,但我得到错误:-131:无效后缀我有什么想法解决我的问题? 有关信息,我的FieldFox N9918A具有固件版本A.06.18和选项:10,112,210,211,233,235,236,302,307,308,309和310.在此先感谢您的支持 以上来自于谷歌翻译 以下为原文 Hi, I try to configure the scale per division for the Gdelay format of a S21 measure in nanosecond with the command SCPI : DISP:WIND:TRAC1:Y:PDIV 1.0E-9 But I have this error : -222 : the value 1.5E-08 was clipped to the minimum value of 0.01. I think I need to change the unit for the scale like on the instrument but I don't find the corresponding function in the documentation!! I have tried to specify in my command the unit but I obtain the error : -131: Invalid suffix I have you any idea to solve my problem? For information, my FieldFox N9918A have the firmware version A.06.18 and the options: 10,112,210,211,233,235,236,302,307,308,309 et 310. Thanks in advance for your support |
3个回答
是的,我看到同样的事情。
这是一个错误,或者是编写文档的人的严重疏忽。 我提醒了固件人 - 帮助正在进行中。 以上来自于谷歌翻译 以下为原文 Yes, I see the same thing. It is either a bug, or a serious oversight on the part of the person who wrote the documentation. I alerted the firmware person - help is on the way. |
对不起,这是一个错误。
我将在7月的某个时候修复下一个FW版本。 与此同时,我刚刚确认您可以使用DISP:WIND:TRAC1:Y:TOP和DISP:WIND:TRAC1:Y:BOTTom命令将比例设置为您需要的任何值 - 没有不适当的限制。 不完美,但它的工作原理。 以上来自于谷歌翻译 以下为原文 Sorry to say, it is a bug. I will be fixed in the next FW release, sometime in July. In the meantime, I just confirmed that you can use the DISP:WIND:TRAC1:Y:TOP and DISP:WIND:TRAC1:Y:BOTTom commands to set the scale to whatever you need - no undue limits. Not perfect, but it works. |
testd018 发表于 2019-7-4 18:10 谢谢你的回答,我将实施你的建议,直到新的固件。 以上来自于谷歌翻译 以下为原文 thank you for your answers, I'll implement your suggestion until the new firmware. |
1403 浏览 0 评论
2425 浏览 1 评论
2277 浏览 1 评论
2116 浏览 5 评论
3033 浏览 3 评论
1507浏览 1评论
845浏览 0评论
1272浏览 0评论
1405浏览 0评论
GMT+8, 2025-3-9 07:57 , Processed in 1.192248 second(s), Total 46, Slave 41 queries .
