是的,PXB可用于淡化RF信号。
它利用N9020A MXA信号分析仪作为PXB的RF输入。 MXA将RF信号数字化并向下转换为基带,并通过数字总线连接将其发送到PXB以实现实时衰落。 值得注意的是,当今市场上的RF推子也在基带上应用衰落,PXB具有可比较的衰落性能.PXB的方法允许测试工程师利用他们现有的MXA进行RF衰落测试,然后将其重新部署用于其他目的。 设置简单,PXB无缝管理自动功率校准。除了RF衰落外,PXB还可用于多通道基带生成和每通道高达512 Msa的信号捕获。 它目前支持20多种校准配置,最高可达4x2 MIMO。 有关更多信息,请访问http://www.agilent.com/find/pxb 以上来自于谷歌翻译 以下为原文 Yes, the PXB can be used to fade RF signals. It leverages the N9020A MXA signal analyzer as the RF input to the PXB. The MXA digitizes and down converts the RF signal to baseband and send it to the PXB for real-time fading via a digital bus connection. It should be noted that RF faders in the market today also applies fading at baseband and the PXB exhibits comparable fading performance. The PXB’s approach allows test engineers to leverage their existing MXAs for RF fading test and redeploy them for other purposes afterwards. The setup is simple with automated power calibration managed seamlessly by the PXB. In addition to RF fading, the PXB can be used for multi-channel baseband generation and signal capture up to 512 Msa per channel. It currently supports over 20 calibrated configurations, up to 4x2 MIMO. For more information, please visit http://www.agilent.com/find/pxb |
我看到这个连接在“PXB RF衰落捆绑程序”中使用(http://cp.literature.agilent.com/litweb ... 5486EN.pdf)可以获得这个intstrumens配置的示例代码:如何
PXB为MXA / MXB进行设置? 以上来自于谷歌翻译 以下为原文 as I see this connection is used in "PXB RF Fading Bundle Program" (http://cp.literature.agilent.com/litweb ... 5486EN.pdf) It is posible to get sample code for this intstrumens configuration: how to PXB make settings for MXA/MXB? |
1511 浏览 0 评论
2492 浏览 1 评论
2339 浏览 1 评论
2189 浏览 5 评论
3123 浏览 3 评论
1711浏览 1评论
919浏览 0评论
1511浏览 0评论
GMT+8, 2025-4-23 11:57 , Processed in 1.072532 second(s), Total 46, Slave 40 queries .
