嗨,Selmanerg,
我们很抱歉地说,目前我们没有任何参考方案设计NoBL SRAM。然而,由于部分工作在相对较低的频率,我们可以连接它的引脚到引脚(从FPGA到内存)。但我们总是建议客户进行相同的SI模拟,并检查信号是否良好,有或没有终止。 如果您想添加端接电阻,则通常建议在时钟和数据信号上使用串联终止或上拉(下拉)终止,并根据信号完整性如何来选择地址和控制信号。请检查此链路F。或更多细节: HTTP://www. CyPress?COM/?ID=4和;RID=30075 一件事,你可能要小心的是解耦电容器将在设计中使用。我想下面的文章将帮助您设计去耦电容器。 我们也可以审查你的示意图,一旦你做了同样的事情。 当做 岩溶岩 以上来自于百度翻译 以下为原文 Hi Selmanerg, We are sorry to say that currently we don't have any reference schematic design for NoBL SRAM. However, since the part operates at comparatively low frequency, we can connect it pin to pin (from FPGA to Memory). But we always recommend our customers to perform SI Simulations for the same and check if the signals look good with or without terminations. If you would like to add termination resistors, then it is typically recommended to use series termination or pull-up (pull-down) termination on the clocks and the data signals, and optionally on the address and the control signals depending on how the signal integrity looks. Please check this link for more details: http://www.cypress.com/?id=4&rID=30075 One thing which you might have to take care would be the decoupling capacitors to be used in the design. I think the following article would help you with the Design of Decoupling Capacitors We can also review your schematic once you are done with the same. Regards PSoCRocks |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1242浏览 2评论
GMT+8, 2025-3-6 02:08 , Processed in 0.924792 second(s), Total 45, Slave 39 queries .
