我们正在开发一个与几个带有Spartan 6的ADC一起使用的板。我们决定使用SPI闪存并使用主SPI编程模式。
既然我们以前从未这样做过(我们一直在使用Xilinx闪存),我想知道ifourunderstanding不正确,并希望得到任何帮助和建议: 1.我们将使用ISE Webpack生成比特流。 2.然后我们将生成一个新文件,由SPI闪存使用,包含上一步中获得的比特流。 3.现在我们将使用iMPACT工具向Spartan 6下载“SPI Flash编程”比特流,该工具将从PC接收数据,以便使用步骤2中生成的文件对SPI进行编程。 4.我们将使用PROG_B使用SPI中的新数据重启Spartan 6。 做完了!! 我们从目前为止阅读的文档中了解到这一点。 提前致谢!! 以上来自于谷歌翻译 以下为原文 We are developing a board for use with several ADCs with a Spartan 6. We've decided to use a SPI Flash memory and use the Master SPI programming mode. Since we've never done this before (we've been using Xilinx Flash memories), I'd like to know if our understanding is correct and would appreciate any help and suggestions: 1. We'll generate the bitstream using the ISE Webpack. 2. Then we'll generate a new file, to be used by the SPI Flash memory, containing the bitstream obtained in the previous step. 3. Now we'll download to the Spartan 6 a "SPI Flash programming" bitstream, using the iMPACT tool, which will receive the data from the PC in order to program the SPI using the file generated in step 2. 4. We'll use PROG_B to reboot the Spartan 6 using the new data from the SPI. 5. Done!! We understand this from the documentation read so far. Thanks in advance!! |
比特流无法写入闪存,因此您必须使用iMPACT工具生成PROM文件,该文件将驻留在SPI闪存芯片中。
以上来自于谷歌翻译 以下为原文 bitstrean cannt be writen to the flash so you have to use the iMPACT tool to generate a PROM file that will be the file that will reside in the SPI Flash chip. |
感谢您的回复。
不,我不想将比特流下载到FLASH,我知道我不能。 我认为我们必须做的是生成应用程序比特流,使用iMPACT基于此应用程序比特流文件生成SPI Flash,然后: 1.将“Flash编程”比特流下载到FPGA 2.通过FPGA下载iMPACT生成的SPI Flash应用程序文件。 我的意思是,使用FPGA使用iMPACT生成的应用程序文件对闪存进行编程。 最后,重新启动FPGA以从SPI Flash加载自身。 谢谢!!! 以上来自于谷歌翻译 以下为原文 Thanks for your reply. No, I don't want to download the bitstream to the FLASH, I know I can't. What I think we must do, is generate the application bitstream, use the iMPACT to generate the SPI Flash based on this application bitstream file and then: 1. Download a "Flash programming" bitstream to the FPGA 2. Download the SPI Flash application file generated by the iMPACT through the FPGA. I mean, use the FPGA to program the Flash memory using the application file generated by the iMPACT. Finally, restart the FPGA to load itself from the SPI Flash. Thanks!!! |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
200浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 17:49 , Processed in 1.123394 second(s), Total 44, Slave 39 queries .
