对于我正在研究的项目,我必须能够切换珀耳帖元件(或其他器件)的极性,并能够线性控制通过珀耳帖的电流。
我不想在这个系统中使用普通继电器来做机械磨损,所以H桥是最好的选择。在阅读数据表后,VNH2SP30是我认为最好的选择。所以设计是基于这个H桥。 我用这个H-Bridge制作了原型PCB,并看到了对线性电流控制的意外反应。 (线性电流控制是一个OPAMP,基于MOSFET的电路,我之前已经使用了很多次,这个电路在PCB上作出预期的反应/工作) 当我启用INA时,启用PWM到DC值,所以假设PWM为100%并限制最大直流电流,让2Adc通过珀耳帖。根据我使用的电流限制设置,H桥的输出将以类似PWM的占空比脉冲。电流限制越高,PWM占空比越高。当电流达到可以通过珀耳帖(在15Vdc PSU)的最大值时,H桥的输出是稳定的100%''PWM''。 在阅读了数据表后,我的印象是可以在直流配置中使用这个H桥(带有0Hz的'PWM'')。所以我的问题是,输出上的PWM来自哪里?这是VNH2SP30的正常行为吗? 当电流限制设置为2A时,将拍摄下图中显示的信号 电路: #h-bridge#vnh2sp30 以上来自于谷歌翻译 以下为原文 For a project I'm working on I have to be able to switch the polarity of a peltier element (or other device) and be able to linear control the current through the peltier. I didn't want to put a normal relay in this system do to the mechanical wear, so a H-bridge was the best option. The VNH2SP30 was the best choise in my opinion after reading the datasheet. So the design was made based on this H-bridge. I have made a prototype PCB with this H-Bridge and saw a unexpected reaction to the lineair current control. (The lineair current control is a OPAMP, MOSFET based circuit I have used many times before and this circuits reacts/works as expected on the PCB) When I enable INA, enable the PWM to a DC value so lets say a PWM of 100% and limit the max dc current to lets say 2Adc through the peltier. The Output of the H-bridge will pulse in a PWM-like dutycycle based on the current limit setting I use. The higher the current limit the higher the PWM duty-cycle. When the current reaches maximum that is possible to go through the peltier (at a 15Vdc PSU) the output of the H-Bridge is a stable 100% ''PWM''. After reading the datasheet I was under the impression that it was possible to use this H-Bridge in a DC configuration (with a 0Hz ''PWM''). So my question is, where does the PWM on the output come from? Is this normal behaviour for the VNH2SP30? The signals displayed in the images below are taken when the current limit was set to 2A Circuit: #h-bridge #vnh2sp30 |
你好论坛成员,
自从我发布上述问题已经有一段时间了,过去几个月我没有得到任何答案,没有人知道解释问题的原因是什么? https://my.st.com//content/ccc/resource/technical/document/datasheet/group2/66/b8/f5/2c/9a/66/41/c7/CD00043711/files/CD00043711.pdf/jcr :内容/翻译/ en.CD00043711.pdf 我希望有人可以给我一个解释,这样我就可以轻松搞定设计;) 先谢谢你! (该设计完美适用于必须做的事情,但这是一个'小'点我真的想要回答,只是为了减轻我作为设计师/程序员的好奇心;)) 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello Forum members, It has been a while since I posted the question above and I haven't had any answers in the past months, does no one have an idea what the cause is of the explained problem? https://my.st.com//content/ccc/resource/technical/document/datasheet/group2/66/b8/f5/2c/9a/66/41/c7/CD00043711/files/CD00043711.pdf/jcr:content/translations/en.CD00043711.pdf I hope someone can give me an explanation so I can get an ease of mind for the made design ;) Thank you in advance! (The design works perfectly for what is has to do but this is a 'small' point I really would like an answer to, just for easing my curiosity as a designer/programmer ;) ) Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
918 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
978 浏览 0 评论
3134 浏览 1 评论
3406 浏览 1 评论
1998 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
152浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
175浏览 5评论
193浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
230浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
176浏览 5评论
GMT+8, 2025-7-6 07:33 , Processed in 0.609294 second(s), Total 46, Slave 40 queries .
