HII正在对我的项目本地化,需要使用UTF-8编码的字符串。我有一切工作代码,但在编辑器中,字符串显示,如果编码的ANSI拉丁代码页。我了解到,在开始新项目时可以选择UTF-8编码,关于如何为现有项目选择UTF-8编码?只有带有字符串的文件需要UTF-8。你能为个人文件选择UTF-8吗?谢谢
以上来自于百度翻译 以下为原文 Hi I am working on localization on my project, and need to use UTF-8 encoding for the strings. I have everything working code-wise, but in the editor the strings are displayed as if coded with the ANSI Latin code page. I read that you can select UTF-8 coding when you start a new project, abut how do you select UTF-8 coding for an existing project? Only the files with the strings need to be UTF-8. Can you select UTF-8 for individual files? Thanks |
3个回答
EnCOONE选项在项目属性对话框的一般页面中。我认为你只能改变整个项目的编码。
以上来自于百度翻译 以下为原文 The encoing option is in the General page of the Project Properties dialog. I think you can only change the encoding for the whole project. |
谢谢,我找到了。它工作正常,但是现在当我打开一个文件时,我得到了警告“
以上来自于百度翻译 以下为原文 Thanks I found it. It works, but now when I open a file I get the warning " How does the editor know which encoding the file has? Is there a way of changing the encoding for all files? Opening and saving each individually would take a long time, there are tons of files. Thanks |
再次回答我自己的问题。我发现了为什么我得到了“不能安全打开”的消息。在我们的文件头上的版权通知包括版权符号(C在圆圈内),这是一个特殊的ANSI字符。我删除它,一切都很好。如果MPLAB-X有这个选项,在每个文件的基础上编码还是不错的。
以上来自于百度翻译 以下为原文 Answering my own question again. I found out why I got the "cannot be safely opened" message. The copyright notice on our file header includes the copyright symbol (c inside a circle), which is a special ANSI character. I remove that and everything works OK. Still would be nice to encode on a per file basis if MPLAB-X has that option. |
5341 浏览 9 评论
2084 浏览 8 评论
1988 浏览 10 评论
3264 浏览 3 评论
2301 浏览 5 评论
846浏览 1评论
741浏览 1评论
682浏览 1评论
739浏览 0评论
629浏览 0评论
GMT+8, 2025-2-11 17:08 , Processed in 0.948594 second(s), Total 51, Slave 45 queries .
