嗨,我用PSOC5开发包CY8CKIT-1001与CY8C5LP家族和Psoc Creator 2,我用蓝牙发送数据到PC。以前,它工作没有问题,但现在它不能正常工作,断电后,与PC的通信没有正确地建立,直到我按下工具箱板上的重置按钮。原因何在?问候Salima
以上来自于百度翻译 以下为原文 Hi, I am using the PSoC5 development kit CY8CKIT-001 with CY8C5Lp Family and Psoc Creator 2.0, and i send data to the Pc with Bluetooth. previously it worked without problems, but now it doesn´t work correctly, after power off-on the communication with Pc is not correctly established until i press the reset button on the Kit Board. what could be the reason? regards Salima |
6个回答
嗨,SZaari You说“关机”只是在BT设备上的意思,PSoC还活着吗?如果是这样,似乎BT设备需要重新初始化,简单地说。还是另一个问题?
以上来自于百度翻译 以下为原文 Hi SZaari You said "power off-on" It's mean off-on only BT device and PSoC is still alive? If so, it seems BT device need to re-initializing, simply. Or another issue? |
我的意思是完整的系统PSoC板和BT模块
以上来自于百度翻译 以下为原文 no I mean the complete system psoc board and BT module |
我写了一个错误,我有CY8C55家族而不是CY8C58LP家族
以上来自于百度翻译 以下为原文 I have written an error, I have CY8C55 Family and not CY8C58LP Family |
我看,这似乎是电子启动序列的问题。温启动:BT在接受启动命令时电子稳定。另一方面,冷启动:当BT接受启动命令时,BT不足以上升。因此,在将初始命令提交给BT模块进行测试之前,最好设置CyDelphi。好啊?
以上来自于百度翻译 以下为原文 I see, It seems issue of start up sequence on electronically. Warm start: the BT is stable in electronically when accept initiate command. The other hand, Cold start: when the BT accept initiate command, BT is not enough to rise up. So, you would be better set CyDelay before submit the initial command to the BT module for a TEST. OK? |
自从它正常工作以来,你改变了什么?(即使它似乎无关)。
你能再描述一下:蓝牙模块是什么?通信过程是怎样的(PC端的软件是什么)? 以上来自于百度翻译 以下为原文 What did you change since it was working correctly? (Even if it seems unrelated). Can you describe a little bit more: what Bluetooth module? How is the communication process (what software on the PC side)? |
现在它又工作了,昨天我在BT模块的初始命令之前删除了CyDelay。谢谢
以上来自于百度翻译 以下为原文 now it works again, yesterday I deleted CyDelay before the initial command to the BT module. Thanks |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
276浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 05:34 , Processed in 0.701148 second(s), Total 53, Slave 48 queries .
