我得到的错误如下:
错误:M0145'(PIN)'P4不能用于路由连接。 我们正在尝试使用整个端口四来运行PSO4上的SPI。在数据表中,它说SPI为这个端口工作,但是当我们尝试在PSoC创建者中实现它时,它给了我们这个错误。 有什么建议吗?思想? 以上来自于百度翻译 以下为原文 The error that I am getting is the following: ERROR: M0145 '(the pin)' P4 cannot be used for routed connections. We are trying to use the entire port four to run our SPI on the PSoC 4. In the datasheet it says that SPI works for this port but when we try to implement it in PSoC creator, it is giving us that error. Any suggestions? Ideas? |
嗨,泰勒杰威尔逊,你用了什么SPI?哪个SPIX主控或SPI(SCB模式)?我猜是斯派克大师。在PSoC4中,通常的SPI模块不能分配给专用引脚。此外,SPI(SCB模式)必须分配给专用引脚。在蓝色打印中显示PIN分配对话框。SPI(SCB模式)的数据表说[接口特定引脚被埋入组件内,因为这些引脚使用专用连接,并且不能作为通用信号可路由。请参阅芯片威廉希尔官方网站
参考手册(TRM)中的I/O系统部分以获取更多信息。好吗?
以上来自于百度翻译 以下为原文 Hi tylerjaywilson What kind of SPI did you use? Which SPI_Master or SPI(SCB mode)? I guess it was SPI_Master. In PSoC4, Usual SPI module can't assign to dedicated Pins. Besides, SPI(SCB mode) must assign to dedicated Pins. That shows pin assignment dialog in Blue print. Data sheet of SPI(SCB mode) say [ The interface specific pins are buried inside component because these pins use dedicated connections and are not routable as general purpose signals. See the I/O System section in chip Technical Reference Manual (TRM) for more information. ] OK? |
在TRM中陈述如下:
7.17对港口4的限制 端口4没有专用端口适配器(第161页上的端口适配器块)。因此,端口4引脚中的任何一个都不能通过DSI路由。然而,端口4引脚仍然可以用作固件PIN、LCDYCOM、LCDY-SEG或可以通过HSIOM连接到SCB块。 问候,Dana。 以上来自于百度翻译 以下为原文 In the TRM the following is stated - 7.17 Restrictions on Port 4 Port 4 does not have a dedicated port-adapter (Port Adapter Block on page 161). Therefore, none of the port 4 pins can be routed through the DSI. However, port 4 pins can still be used as a firmware pin, LCD_COM, LCD_SEG or can be connected to the SCB block through the HSIOM. Regards, Dana. |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1866 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1549 浏览 1 评论
605浏览 2评论
451浏览 2评论
448浏览 2评论
400浏览 2评论
1082浏览 2评论
GMT+8, 2025-1-12 03:00 , Processed in 0.749987 second(s), Total 46, Slave 41 queries .
