什么样的MCU可以用来编程PSoC4芯片(4200 L系列)?
以上来自于百度翻译 以下为原文 What MCU can be used to program PSoC4 chips (4200 L series) ? |
7个回答
答案必须是“任何MCU都能编程PSoC”;
也许你想知道你需要什么样的程序员。有两种选择: 使用MIXPRO3是最干净的解决方案。没有自制的黑客,它对每一个PSoC都是现成的。 使用一个Kitprog,它是所有原型包的一部分,可以作为CY8CKIT-043进行调试。 鲍勃 以上来自于百度翻译 以下为原文 The answer must be "Any MCU can program a PSoC" ;-) Probably you'd like to know what kind of Programmer you need. There are two choices: Use a Miniprog3 which is the cleanest solution. no self-made hacks, it works out-of-the-box for every PSoC. Use a Kitprog which is a snap-off part of all the prototype kits that allow for debugging as the CY8CKIT-043. Bob |
ncmza 发表于 2019-7-2 15:40 你好,鲍伯,我正在尝试使用PSoC4MCU IC构建接近传感器。我想用IC代替原型设计工具包(最好)根据我的设计条件——参考附图。 HTTP//I.IGGURUR.COM/QB4A2BL.JPG 我需要通过接近感测来测量表面A和B之间的距离。我将建立一个表面上的接近传感器,并将其连接到PSoC设备。我关心的是我如何将它与其他像计算机一样的外围设备连接起来?集成电路板要完成什么其他的部分?如何编程PSoCTO得到实时的接近距离/变化? P.S.:-我是一个嵌入式和硬件设计新手。如果我在某些情况下是错的,请告诉我。 以上来自于百度翻译 以下为原文 Hello bob, I am trying to build a proximity sensor using the PSoC4 MCU IC. I would like to build it using the IC instead of the prototyping kit (preferably) given my design conditions - refer to the attached image. http://i.imgur.com/qB4a2bl.jpg I need to measure the distance between the surfaces A and B through proximity sensing. I will build the proximity sensor on one of the surfaces and connect it to the PSoC device. My concern is how do I interface it with other periferals such as the computer ? what other parts do i require with the IC to complete the board? how do I program the PSoC to get the real time proximity distance/changes in it? P.S. :- I am a novice in embedded and hardware design. If I am wrong in certain case please let me know. |
我怀疑是否有可能使用CopSeq测量距离。Capsense被用来检测人体按压开关或接近传感器导线。相当于一个2mm距离测量垫。在页面顶部的“关键字搜索”字段中输入“CasSoad布局”并阅读…
顺便说一句,首先使用原型套件总是明智的。附有一个程序员/调试器接口,您将很容易看到结果。当你的原型运行时,你可以考虑制作你自己的PCB。 鲍勃 以上来自于百度翻译 以下为原文 I question if it is possible measuring distances using capsense. Capsense was made to detect human body pressing a switch or approaching a sensor wire. Quite more than a 2mm distance measure of a pad. Enter "capsense layout" into the keyword search field at top of this page and read... btw: It is always advisable to use a prototype kit at first. There is a programmer / debugger interface attached and you will easily see results. When your prototype runs you may think about making your own pcb. Bob |
ncmza 发表于 2019-7-2 16:18 谢谢鲍伯,这很有帮助。但是,CAPSENSE仅仅是用来检测人体皮肤的吗?它也能抵抗塑料吗? 我的限制是,我必须设计一个PCB并连接到塑料表面上的传感器垫。但我先试试这个原型。但是,在那种情况下,我可以在表面上有铜垫/跟踪,并把它连接到工具箱的I/O上吗?这样行吗?或者传感器垫仅在试剂盒本身? 谢谢阿曼 以上来自于百度翻译 以下为原文 Thanks Bob.That was helpful. But, is capsense only designed to detect human skin? Can it work against plastic as well? My constraints were such that I had to design a pcb and connect to the sensor pad on the plastic surface. But I will try the prototyping kit first then. But in that scenario can I have copper pad/trace on the surface and connect it to the i/o of the kit? Will that work ? or is the sensor pad only on kit itself? Thanks Aman |
在CY8CKIT-043 PSoC M原型试剂盒上,没有一个用于CopSun的铜痕迹。所以你可以自由设计自己的按钮。我在架空箔上涂了一些导电油墨。工作!
鲍勃 以上来自于百度翻译 以下为原文 On a prototyping kit as the CY8CKIT-043 PSoC M Prototyping Kit are no copper traces for capsense. So you are free to design your own buttons. I used some conductive ink on overhead foil. Worked! Bob |
ncmza 发表于 2019-7-2 16:39 嘿,鲍伯,再次谢谢你。我会把引脚连接到铜带上的塑料夹持器。 另一个问题-我相信我可以通过套件获得模拟值,但是测量的分辨率是多少?或者什么是最小的“位移变化”,我可以测量,什么是最小和最大距离,我可以从这个系统获得? 问候,阿门洲 以上来自于百度翻译 以下为原文 Hey bob, thanks again. I will connect the pin to a copper tape over the plastic gripper. Another question - I believe that I can get analog values through the kit, but what will be the resolution of measurement? or what is the minimum 'displacement change' i can measure and what are the min. and maximum distances I can obtain from this system? Regards, Aman |
最好是先安装KIT软件(创建者4.1),然后为你选择的芯片浏览组件。每个组件都有一个数据表,它描述了它的功能、API和-在适当的时候——AC和DC特性。
鲍勃 以上来自于百度翻译 以下为原文 Best is to install the kit software (Creator 4.1) first and go through the components for your selected chip. Every component has got a datasheet which describes its function, APIs and -when appropriate- AC and DC characteristics. Bob |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 16:51 , Processed in 1.175875 second(s), Total 90, Slave 74 queries .
