我下载了选择器工具,但没有迹象表明哪个微支持外部晶体。我有兴趣知道是否有任何评估部件支持外部晶体。理想情况下,8针设备将支持我的应用程序。有谁知道哪些设备支持外部水晶?
谢谢 丰富 以上来自于谷歌翻译 以下为原文 I downloaded the selector tool, but there is no indication of which micros support an external crystal. I am interested in knowing if any of the valueline parts support an external crystal. Ideally, the 8-pin device would support it for my application. Does anyone know which devices support an external crystal? Thanks Rich |
4个回答
理查德你好,
使用STM8CubeMX是一种简单的解决方案,可以检查设备是否支持外部晶振。 如果您对STM8S超值系列MCU特别感兴趣,那么在MCU选择器中请通过应用如下图所示的滤波器缩小设备列表: 一旦通过双重克隆选择器件,您可以通过打开RCC项目并检查是否有名为HSE:Crystal / Ceramic Resonator的选项来检查外部晶体支持。通过这种方法,您可以在下面看到,例如STM8S003F3Px支持外部晶振。 关于您的问题:所有STM8S超值线路器件都支持外部晶振,但8引脚STM8S001J3除外,它只有一个外部时钟输入。 我希望这些信息对您有所帮助。 问候 Szymon 以上来自于谷歌翻译 以下为原文 Hello Richard, Using of STM8CubeMX is an easy solution how you can check if device supports an external crystal. If you are particularly interested in STM8S Value Line MCUs, then in MCU selector please shrink the list of devices by applying the filter like on picure below: Once you select the device by double-clinking on it, you can check external crystal support by opening RCC item and by checking if there is an option named HSE: Crystal/Ceramic Resonator. With this approach you can see below that for example STM8S003F3Px supports external crystal. Regarding your question: all STM8S Value Line devices support external crystal except 8-pin STM8S001J3, which has only one input for external clock. I hope this information will be helpful to you. Regards Szymon |
理想情况下,8引脚器件会支持它 “ 根据我的知识,没有那么多8针STM8S:1。 通过其数据表比在计算机上安装cubemx更容易。 以上来自于谷歌翻译 以下为原文 ' Ideally, the 8-pin device would support it ' there aren't that many 8-pin STM8S: 1 to my knowledge. it is easier to go through its datasheet than getting cubemx installed on your computer. |
“理想情况下”,8引脚器件应具有良好的内部振荡器,以便不会为外部引脚消耗有价值的引脚。
以上来自于谷歌翻译 以下为原文 'Ideally', 8-pin devices should have good internal oscillators in order to not consume valuable pins for external ones. |
2829 浏览 1 评论
3270 浏览 1 评论
1844 浏览 1 评论
3694 浏览 6 评论
6100 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
395浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
487浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
316浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
235浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
339浏览 2评论
GMT+8, 2025-2-3 22:11 , Processed in 0.966442 second(s), Total 50, Slave 45 queries .
