我是一名软件工程师。
我看到使用FPGA与软件集成的巨大潜力,所以我试图在FPGA上实现智能化。 我有一个Spartan 6 LX45 -3和一个100 MHz的微细纤维核心。 有人能指出我在LX45 -3中实现软件定义无线电的信息吗? 它甚至可能吗? 我能找到的只有Zynq和专用SDR硬件的信息。 我可以将多少收音机放入Spartan 6 LX45? 此外,是否有人知道我可以在哪里购买或找到有关构建放大器和天线的信息? 我不想购买已经上面的所有东西的电路板。 我想学习如何将所有内容与我已有的主板集成,并保持小巧。 以上来自于谷歌翻译 以下为原文 I'm a software engineer. I see tremendous potential in using FPGA's integrated with software so I'm trying to get smart on FPGA's. I have a Spartan 6 LX45 -3 with a 100 MHz microblaze core. Can somebody point me to information on implementing a software defined radio in an LX45 -3? Is it even possible? All I can find is information on the Zynq and dedicated SDR hardware. How much of the radio can I put into a Spartan 6 LX45? Also, does anybody know where I can purchase or find information on building the amplifier and antenna? I don't want to purchase a board with everything already on it. I want to learn how to integrate everything with the board I already have, and keep it small. |
7个回答
男,
使用FPGA器件的SDR与FPGA器件本身一样古老(人们从FPGA器件的第1天就开始这样做了)。 随着设备功能越来越强,设计变得越来越复杂。 至于学习它,你有很多阅读要做 - 它几乎是任何人都可以找到的,只需使用谷歌(或你最喜欢的搜索引擎)。 甚至还有使用Virtex 6设备的火腿无线电: http://www.radiocronache.com/tag/virtex-6-fpga/ 我建议您查看ARRL.org等SDR硬件或TAPR.org组。 http://www.arrl.org/ http://www.tapr.org/hpsdr_index.html 既然Xilinx有HLS(基本上是c到门),我想我们已经能够以更容易的方式使用更多的SDR。 http://www.xilinx.com/tools/autoesl_instructions.htm Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m, SDR using FPGA devices is as old as the FPGA device itself (people have been doing this since day 1 of the FPGA device). As the devices get more capable, the designs get more complex. As for learning about it, you have a lot of reading to do -- it is all out there pretty much for anyone to find, b7y simply using google (or your favorite search engine). There is even a ham radio using a Virtex 6 device: http://www.radiocronache.com/tag/virtex-6-fpga/ I suggest you look at ARRL.org and such for SDR hardware, or the TAPR.org group. http://www.arrl.org/ http://www.tapr.org/hpsdr_index.html Now that Xilinx has HLS (basically, c to gates), I imagine we have enabled many more to play with SDR in an easier fashion. http://www.xilinx.com/tools/autoesl_instructions.htm Austin Lesea Principal Engineer Xilinx San Jose |
我确实谷歌它,并找到了很多材料。
但正如您也指出的那样,它们适用于Virtex和其他硬件。 HLS链接适用于不支持Spartan的Vivado,除非我弄错了。 我真的在寻找使用Spartan 6 LX45的例子。 我找到了一个例子,他们提到他们使用的是Spartan 6 LX45,但它是在专用主板上,没有关于HDL或主板上其他组件的信息。 以上来自于谷歌翻译 以下为原文 I did google it and did find a lot of material. But as you also pointed out, they were for the Virtex and other hardware. The HLS link is for Vivado which doesn't support Spartan, unless I'm mistaken. I was really looking for examples that use the Spartan 6 LX45. I found one example that mentioned they used a Spartan 6 LX45, but it was on a proprietary board with no information on the HDL or other components on the board. |
mbenson1写道:
我确实谷歌它,并找到了很多材料。 但正如您也指出的那样,它们适用于Virtex和其他硬件。 HLS链接适用于不支持Spartan的Vivado,除非我弄错了。 我真的在寻找使用Spartan 6 LX45的例子。 我找到了一个例子,他们提到他们使用的是Spartan 6 LX45,但它是在专用主板上,没有关于HDL或主板上其他组件的信息。 您可能需要进行一些工程设计,并了解Virtex设计所使用的仅存在于Virtex器件中的功能。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 mbenson1 wrote:You'll probably have to do some engineering and see what features the Virtex designs used which exist only in the Virtex devices. ----------------------------Yes, I do this for a living. |
C,
我很佩服。 干净整洁的视频。 像你一样输入evrything并不容易,并且让它全部工作(没有拼写错误!)。 我期待更多像这样.... Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 c, I am impressed. Nice and clean video. Can't be easy to type evrything like you did, and have it all work (no typo's!). I look forward to more just like this.... Austin Lesea Principal Engineer Xilinx San Jose |
谢谢你的客气话Austin,很高兴你认为这是一个有用的例子!
如果我能够使用zivboard,可以使用vivadoo做一些正确的示例。 以上来自于谷歌翻译 以下为原文 Thanks for your kind words Austin, glad you thought it a useful example! If I ever get my hands on a zedboard can do some proper examples using vivadoo. |
C,
请通过austin@xilinx.com与我联系 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 c, Contact me at austin@xilinx.com Austin Lesea Principal Engineer Xilinx San Jose |
2568 浏览 7 评论
2904 浏览 4 评论
2359 浏览 9 评论
3453 浏览 0 评论
2540 浏览 15 评论
2972浏览 1评论
700浏览 1评论
573浏览 1评论
864浏览 0评论
GMT+8, 2025-4-6 07:17 , Processed in 1.754541 second(s), Total 88, Slave 71 queries .
