您好,我正在使用函数发生器U2761A。
当我使用SCPI命令:APPL:SIN 2000,1 VPP,0如SCPI命令的程序员手册中所述,输出为+ 1V至-1V的正弦波。 我相信当DC偏移为0V时,VPP(峰峰值)的定义应从+ 0.5V延伸到-0.5V。 你能否解释一下这个观察结果? 在这种情况下,VPP是否代表“峰 - 峰”? 为了帮助我,当我查询幅度“高”和“低”时,我确实分别接收+ 0.5V和-0.5V。 输出负载设置为500欧姆。 先谢谢你。 以上来自于谷歌翻译 以下为原文 Hi there, I am using the function generator U2761A. When I use the SCPI command: APPL:SIN 2000, 1 VPP, 0 as described in the programmer's manual for SCPI commands, the output is a sine wave ranging from +1V to -1V. I believe the definition of VPP (peak to peak) should extend from +0.5V to -0.5V when there is a DC offset of 0V. Can you please offer an explanation of this observation? Does VPP in this case represent "peak-to-peak"? To help out, when I query for the amplitude "high" and "low", I do receive +0.5V and -0.5V respectively. The output load is set to 50Ohm. Thank you in advance. |
3个回答
我没有使用过这个特定的函数生成器,但这是一个非常常见的函数生成器问题。
通常原因是测量设备或DUT的阻抗。 数字万用表和大多数/非所有示波器都是高阻抗。 函数发生器的输出阻抗固定为50欧姆,因此当输出应用于Hi-Z器件时,该值似乎是您所期望的两倍。 这是我之前制作的不同fgen的帖子。 该解释也适用于此函数发生器:输出电压是我设置的值的两倍/两倍。 以上来自于谷歌翻译 以下为原文 I haven't used this particular function generator, but this is a pretty common function generator question. Usually the cause is the impedance of the measuring device or DUT. DMMs, and most/not all oscilloscopes are high impedance. The output impedance of the function generator is a fixed 50 ohms so when an output is applied to a Hi-Z device, the value appears to be double what you would expect. Here is a previous post for a different fgen I made. The explanation should apply to this function generator as well: The output Voltage is twice/double the value I set. |
是的我相信错配输入阻抗是原因。
我目前没有成功纠正这个问题。 我可以将U2671a设置为highZ,我相信读出的值类似于99E36欧姆,使用命令OUTPUT:LOAD?。 但是,示波器输入阻抗为1Mohm,被认为是“高”。 在典型的分压器中,Vout = R2 /(R2 + 99E36),我应该期待0v输出,因为R1(来自函数发生器)现在要高得多吗? 谢谢! 以上来自于谷歌翻译 以下为原文 Yes I believe the mismatch input impedance is the cause. I have been unsuccessful in correcting this at the moment. I can set the U2671a to highZ, I believe the read out value is something like 99E36 ohm, using the command OUTPUT: LOAD?. However, the scope input impedance is 1Mohm, and that is considered "high". In a typical voltage divider, Vout = R2/(R2+99E36), should I expect a 0v output because the R1 (from the function generator) is so much higher now? Thanks! |
客来看我可怜我看 发表于 2019-6-28 07:58 不,函数发生器输出阻抗是固定的。 你只需告诉它负载阻抗,它就可以为你做数学计算。 对于1Mohm或更高的负载,数学计算都是相同的。 如果您的函数发生器设置为50欧姆,则输出将是您设置的值的两倍。 如果将其设置为Hi-Z,您将获得预期值。 以上来自于谷歌翻译 以下为原文 No, The function generator output impedance is fixed. You just tell it the load impedance and it does the math for you. The math all works out the same for loads 1Mohm and higher. If you have your function generator set for 50 ohms, the output will be double the value you set. If you set it for Hi-Z, you will get the expected value. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1426浏览 1评论
827浏览 0评论
1195浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 22:14 , Processed in 1.336808 second(s), Total 78, Slave 63 queries .
