嗨,我最近开始使用NA(E5061B),但我遇到了一些困难:我必须进行阻抗测量分析。
我的DUT是石英晶体微量天平。 在初始校准过程之后,我执行阻抗测量,我需要保存整个分析所获得的数据,但此刻我只能保存最后一个“周期”的数据。 这是遵循的路径:SAVE-RECALL>保存跟踪数据>(EXTENSION:.csv)。 如何从头到尾获取所有数据?或者程序会自动保存我的数据以及在哪里可以取回它们? 谢谢你的关注。 我希望你能帮助我。 再见。 附: 对不起我的可怕语言(我是一名绝望的意大利学生)。 以上来自于谷歌翻译 以下为原文 Hi,I recently started working with NA(E5061B), but I have some difficulties: I have to perform impedance measurement analysis. My DUT is a quartz crystal microbalance. After the initial procedure of calibration, I performe the impedance measurement and I need to save the data acquired of the entire analysis, but at the moment I be able to save only data of the last "cycle". This is the path followed:SAVE-RECALL>SAVE TRACE DATA>(EXTENSION: .csv). How can I get all data from beginning to end?Or the program saves my data automatically and where can I get them back ? Thank you for your attenction. I hope you can help me. Bye bye. P.S. Sorry for my terrible language(I am a disperate italian student). |
您提供了保存跟踪数据的命令,但是您没有获得该数据?
或者您需要保存一些其他数据吗? “循环”是什么意思? 如果您的测量重复多次并且您想要这些数据,您还需要保存该跟踪。 以上来自于谷歌翻译 以下为原文 You give the command for save trace data and you do not get that data? or is there some other data you need to save? What do you mean with "cycle" ? Are your measurement repeating several times and you want that data to, you'll also need to save that trace. |
我的乐器没有与任何PC连接。
我只使用我的NA和文本夹具进行阻抗校准,在此操作后我开始测量DUT。 “控制器保存”是什么意思? 所以每次运行分析时都必须设置时间间隔? 谢谢。 以上来自于谷歌翻译 以下为原文 My instrument is not interfaced with any PC. I only use my NA and the text fixture for impedance calibration, after this operation I start measurement of the DUT. What do you mean with "controller save"? So I must set the time interval whenever I run my analysis? Thanks. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1427浏览 1评论
827浏览 0评论
1196浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-25 00:35 , Processed in 1.366895 second(s), Total 79, Slave 63 queries .
