嗨,大家好,
我正在开发一个功能,希望USB控制器,FX3可以通过程序动态地在超高速和高速运行之间进行通信。 但我不知道FX3是否能支持。FX3支持这个功能吗?如果是的话,有人会建议我怎么做吗? 谢谢您。 以上来自于百度翻译 以下为原文 Hi All, I am developing a function that I hope the u*** controller, FX3 can dynamically be switched between Super Speed and High Speed in run-time by program. But I don't know if the FX3 can support. Does the FX3 support this function? if it is, could anyone suggest me how to do? Thank you. |
你好,
是的,FX3在运行时可以在超高速之间切换。 通过调用CYU3pCONTCONSTATE(CYFALSE,CyFalse)强制USB断开,强制USB软件断开;然后再次调用CYU3PCONTCONSTATE(CyTress,CyFalse);(因此,该设备现在重新枚举为高速设备)。 如果您还想还原为超高速,请调用Cyu3pPieltTeC态(CyFalm,CyFalse),后面跟着Cyu3pCelpTeStC态(CyTrand,CyTrue) 当做, - Madhu Sudhan 以上来自于百度翻译 以下为原文 Hi, Yes, FX3 can switch between superspeed to high speed on run time. force a USB Disconnection by calling CyU3PConnectState (CyFalse, CyFalse) to force a software disconnection of USB; and then again call CyU3PConnectState (CyTrue, CyFalse); (so that the device now re-enumerates as a high speed device. If you again want to revert to Super speed, call CyU3PConnectState (CyFalse, CyFalse) followed by CyU3PConnectState (CyTrue, CyTrue) Regards, - Madhu Sudhan |
嗨,Madhu,
可以。谢谢您的准确答复。 当做 蔡吉美 以上来自于百度翻译 以下为原文 Hi Madhu, Okay. Thank you for the accurate response. Regards Jimmy Tsai |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1865 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1545 浏览 1 评论
605浏览 2评论
450浏览 2评论
448浏览 2评论
400浏览 2评论
1081浏览 2评论
GMT+8, 2025-1-11 14:35 , Processed in 0.958807 second(s), Total 78, Slave 62 queries .
