HALO,我使用PIC32 MZ启动套件和扩展板和V1Y08版本的和声。我已经通过SPI为PIC32 MZ2048 EC144建立了一个FRAM存储器。该FRAM存储器类似于微芯片SST25VF020B闪存。它在CMD SPI协议帧和存储器几何上只存在差异。我已经修改了SST25VF020B驱动程序Outlook文件夹。它仍然工作得很好,但是让我不安的是,FRAM驱动程序仍然与sst25vf020b同名。当在HARMony中建立一个新的自己编写的驱动程序时,如何控制编译器将驱动程序初始化数据的源代码集成到system_init.c文件中?在修改SDCard驱动程序以选择诸如PORT_CHANNEL_B之类的芯片选择端口的另一种情况下,和谐配置器的代码生成器希望删除关于该端口B的端口系统服务配置。如何防止和谐代码配置器删除我的源代码中的重要设置?谢谢你的帮助。
以上来自于百度翻译 以下为原文 Hallo, I am using PIC32MZ starter kit and extension board and v1_08 Version of Harmony. I had set up a FRAM-Memory to PIC32MZ2048ECH144 via SPI. This FRAM memory is similar to Microchip sst25vf020b flash memory. It has only differences in cmd spi protocoll frame and memory geometry. I had modify the sst25vf020b driver out harmony folder. It still works well but disturb me the FRAM driver still the same name as sst25vf020b. When a establish a new own written driver in Harmony how can I controll the compiler to integrate sourcecode of driver initialization data into system_init.c file? In another case of modify the SDCard driver to select chip select port like PORT_CHANNEL_B the code generator of Harmony Configurator want remove the ports system service configuration about this Port B. Although I selected PORT_CHANNEL_B in Harmony configurator options. How can I prevent the harmony code configurator to remove important setting in my sourcecode? Thanks for help. Best Regards |
嗨,你还在寻找问题的答案吗?
以上来自于百度翻译 以下为原文 Hi, are you still looking for answers for the questions? |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
486浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 23:41 , Processed in 1.208841 second(s), Total 78, Slave 62 queries .
