各位早上好。
我想尝试两个mocro(SPCEL60系列)交换一些字节。微处理器通过UART连接。我正在使用SPC5 Studio中包含的串行驱动程序。 现在我尝试使用chnWrite和chnRead ol alternatevily sdGet和sdPut。 我正在寻找指令或教程,但我发现只有简单的东西(比如连续发送一些字节)。 我试图解决的问题是随后的: micro A做一些事情并计算一个值。 micro B做同样的事情。 micro A将值发送给B. B收到价值验证是否与他相同。 B将值发送给A. A收到价值。如果值匹配,则两个微启动再次进行计算,直到下一次比较。 我不清楚的是如何实现这种“对话”。这两个微不同步。 如果我正确理解,B应该等待,例如调用chnRead。但是如果在B调用之前微传输那个功能呢?当B调用chnRead时,它会在硬件管理的底层缓冲区中找到值?或者价值丢失而B等待永远? 是否有标准方法适用于通过UART连接的两个微处理器之间实现双向值交换? 问候, Ivab #uart 以上来自于谷歌翻译 以下为原文 Good morning to everyone. I am trying to have two mocro (SPCEL60 family) tha exchange some bytes. The micros are connected via UART. I am using the serial driver in cluded in SPC5 Studio. Now I am tryong to use chnWrite and chnRead ol alternatevily sdGet and sdPut. I am searching for instructions or tutorial, but I found only simple things (like continuosly send some bytes). The problem I am trying to solve is the subsequent: micro A do some thing and calculate a value. micro B do the same thing. micro A send the value to B. B receive the value verify if is the same his. B send the value to A. A receive the value. If the value match, the two micro start again doing calculations, until the next comparison. What I don't clearly understand is how to achieve this sort of ''conversation''. The two micro are not synchronous. If I correctly understand, B should wait, for example calling a chnRead. But if micro transmit before B call that function? When B call the chnRead, it find the value in an underlying buffer managed by the hardware? Or the value is lost and B wait forever? Are there standard methods to apply in order to achieve a two way exchange of values between tow micros connected via UART? Regards, Ivab #uart |
你好伊万,
您不需要同步2微处理器。 通信2个设备应该共享相同的参数 您是否使用了输出格式化程序组件(来自OS-Less或RLE)或Chibios输出格式化程序? 通常,当我通过UART(ESP8266(Arduino),Other Micros ..)进行通信时,我使用此组件。 附件中与ESP8266进行AT通信的源代码示例 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Ivan , You do not need to synchronize the 2 micros. to communicate the 2 devices should share the same parameters Did you use the Output Formatter component (From OS-Less or RLE) or Chibios Output formatter ? Often , when i communicate by UART (ESP8266 (Arduino), Other Micros ..) , i use this component. Example of source code with AT communication with ESP8266 in attachment Best regards Erwan |
2776 浏览 1 评论
3251 浏览 1 评论
1822 浏览 1 评论
3667 浏览 6 评论
6060 浏览 21 评论
1347浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
372浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
465浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
291浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
211浏览 2评论
GMT+8, 2025-1-9 09:38 , Processed in 0.950728 second(s), Total 42, Slave 37 queries .
