2013年3月13日*信号分析仪基础知识和新应用网络广播*的问题与解答*问题:*如何扩展信号分析仪的动态范围?
以上来自于谷歌翻译 以下为原文 Questions and Answers to *Signal Analyzer Fundamentals and New Applications Webcast* on 13 March 2013 *Question:* How can I extend the dynamic range of my signal analyzer? |
*答案:*分析仪的动态范围是测量高电平到低电平信号的能力。
二阶和三阶产品通常限制在存在高电平信号的情况下测量低电平信号的能力。 为了克服这个问题,有必要增加输入衰减以减少失真产物。 随着输入衰减增加,噪声基底上升。 要降低本底噪声,可以降低分辨率带宽,从而使扫描时间减慢1 / RBW ^ 2。 对于测量低电平信号,其他提高灵敏度的方法包括打开前置放大器和使用本底噪声扩展。 以上来自于谷歌翻译 以下为原文 *Answer:* The dynamic range of an analyzer is the ability to measure high level to low level signals. Second and Third Order products often limit the ability to measure low level signals in the presence of high level signals. To overcome this, it is necessary to increase input attenuation to reduce distortion products. As input attenuation is increased, the noise floor rises. To decrease the noise floor you can reduce the resolution bandwidth, which causes the sweep time to slow down by 1/RBW^2. For measuring low level signals, other ways to increase sensitivity include turning on the preamp and using noise floor extensions. |
1288 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1116浏览 1评论
755浏览 0评论
929浏览 0评论
1289浏览 0评论
GMT+8, 2024-12-25 03:40 , Processed in 1.288401 second(s), Total 77, Slave 61 queries .
