2013年3月13日*信号分析仪基础知识和新应用网络广播*的问题和答案*问题:*有人提到参考电平设置因素在早期的幅度精度,但数字IF处理(A / D)不是一个因素?
以上来自于谷歌翻译 以下为原文 Questions and Answers to *Signal Analyzer Fundamentals and New Applications Webcast* on 13 March 2013 *Question:* It was mentioned that reference level setting factors into amplitude accuracy early on, but with digital IF processing (A/D) it's not a factor? |
*答案:*较旧的模拟频谱分析仪具有一个对数放大器,该对数放大器在参考电平校准,并且由于其非线性响应而在参考电平以下测量的电平具有误差。
现代信号分析仪(PSA,PXA,MXA,EXA,CXA,MXE)具有极其线性的数字IF。 线性度从大约dB提高到小于百分之一dB。 这种改进类似于您从模拟盒式磁带转换到光盘的过程。 测量信号的数字化比模拟测量更准确和可预测。 重要的是要记住,改变参考电平会导致衰减的变化,这也会影响幅度精度。 以上来自于谷歌翻译 以下为原文 *Answer:* Older analog spectrum analyzers had a log amplifier that was calibrated at the reference level and had error for levels measured below the reference level due to its non-linear response. Modern signal analyzers (PSA, PXA, MXA, EXA, CXA, MXE) have extremely linear digital IFs. The linearity has improved from about a dB to less than a hundredth of a dB. The improvement is similar to what you would see transitioning from analog cassette tapes to compact discs. A digitization of the measured signal is much more accurate and predictable than an analog measurement. It is important to remember that changing the reference level can result in a change of attenuation which would affect amplitude accuracy, too. |
1394 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2112 浏览 5 评论
3027 浏览 3 评论
1489浏览 1评论
840浏览 0评论
1253浏览 0评论
1394浏览 0评论
GMT+8, 2025-3-6 12:22 , Processed in 1.357922 second(s), Total 76, Slave 60 queries .
