嗨,我不知道这个问题是否与最新的MPLLABX版本一起出现,但是这里是这样的:我想调试我的软件(PIC32mx和声1.8xc32v1.40等),我设置了一个断点,但我的程序只运行了一秒钟,然后如果我点击暂停按钮,它就不会显示程序lo,那么一切都丢失了。阳离子,软件运行良好的释放模式。它会是什么?
以上来自于百度翻译 以下为原文 Hi, I don't know if this issue came with the latest MPLAB X version but here it goes: I want to debug my software (PIC32mx hARMony 1.8 xc32v1.40, etc.) I set a breakpoint but my program only runs for like a second and then everything is lost if I click the pause button it won't show me the program location, the software runs well on release mode. What can it be? |
5个回答
最新的MPLAB X版本,在V3.40?我正在用一个现实调试OK
以上来自于百度翻译 以下为原文 latest MPLAB X version as in V3.40? Mine is Debugging OK with a RealICE |
是的V3.40忘记添加它。很奇怪,我不能无缘无故地调试。我的应用程序没问题,没有任何异常。我从未经历过这样的问题
以上来自于百度翻译 以下为原文 Yes v3.40 forgot to add it. It's very strange I can't debug for no reason. My application is ok, there aren't any exceptions. I've never experienced something like this issue |
这与真正的ICEIt是MplabX或编译器无关。除非您的代码有bug并已逸出,否则不会。您能调试吗?如果你只是在调试器中点击运行,它会起作用吗?你有例外处理程序吗?
以上来自于百度翻译 以下为原文 That is Not an issue with the Real ICE It is MplabX or the Compiler. Unless your code has a bug and has run away, then it is not. Can you debug at all? If you just hit run in the debugger does it work? Do you Have exception Handlers? |
构建过程除了生成程序集指令之外,还生成调试信息,该调试信息解释如何将特定地址的单个程序集指令映射到原始源文件中的代码行。MPLAB X使用这些信息将当前PIC设备PC映射到源代码中的一行代码。上面的消息表示MPLAB X无法将当前PIC PC映射到源代码中的一行代码。通常这种情况发生是因为当前的PC实际上没有映射到源代码行。例如,PC可能处于库例程的中间。或者你的程序可能跳错了,并且正在执行随机的存储器位置。你总是可以使用Windows->PIC内存视图->Program Memory来确切地看到PC在哪里以及正在执行什么操作码。
以上来自于百度翻译 以下为原文 The build process, in addition to generating the assembly instructions, also generates debug information that explains how to map individual assembly instructions at specific addresses to source lines of code in your original source files. MPLAB X uses this information to map the current PIC device PC to a line of code in your source. The message above is saying that MPLAB X is unable to map the current PIC PC to a line of code in your source. Usually this happens because the current PC doesn't actually map to a line of source code. For example, the PC may be in the middle of a library routine. Or your program may have made a bad jump and is executing random memory locations. You can always use the Window -> PIC Memory Views -> Program Memory to see exactly where the PC is and what opcodes are being executed. |
5250 浏览 9 评论
2037 浏览 8 评论
1958 浏览 10 评论
3218 浏览 3 评论
2266 浏览 5 评论
790浏览 1评论
682浏览 1评论
612浏览 1评论
686浏览 0评论
584浏览 0评论
GMT+8, 2024-12-29 12:28 , Processed in 1.175140 second(s), Total 54, Slave 48 queries .
