我把我的电脑的Java更新到1.80Y101-B13(此时最新可用),但是我注意到MPLAB X IDE V3.40仍然使用1.8O091-B14。似乎MPLAB X IDE附带了它自己的Java引擎。它能被告知使用较新的系统范围的Java吗?还是最好别管它?该系统是Windows 10, 64位。
以上来自于百度翻译 以下为原文 I updated my computer's Java to 1.8.0_101-b13 (the newest available at this time), but I noticed that MPLAB X IDE v3.40 still uses 1.8.0_91-b14. It seems that MPLAB X IDE comes with its own Java engine included. Can it be told to use the newer systemwide Java? Or is it best to leave it alone? The system is Windows 10, 64-bit. |
3个回答
是的,它可以看到这个HTTP://www. McCHIP.COM/FUMMS/M88 85.2.ASPX
以上来自于百度翻译 以下为原文 Yes, it can see this http://www.microchip.com/forums/m888552.aspx |
嗨,很久以前(3到4年),MPLAX X在PC上使用Java版本,但是当它被更新时,它会产生问题……然后,MPLAB X所需要的特定Java版本被集成到特定目录中的安装程序中,这样就可以在不产生潜在问题的情况下更新Java。It MPLAB X.如果您在控制面板中启动Java应用程序,那么就有可能拥有多个Java版本,并且如果其他应用程序需要的话,您可以启用多个Java版本。
以上来自于百度翻译 以下为原文 Hi, A long time ago (3 to 4 years), MPLAB X used the Java version on the PC BUT when it was updated it was creating problems... Then, the specific Java version needed by MPLAB X was integrated into the installer in a specific directory so that one can update Java without potentially creating issues with MPLAB X. If you launch the Java application in the control panel, ther is a possiblity to have multiple java versions and you can enable several of them if needed by other applications Regards |
当然,“系统范围的Java”是一个矛盾修辞。
以上来自于百度翻译 以下为原文 Of course, "systemwide Java" is such an oxymoron |
5282 浏览 9 评论
2054 浏览 8 评论
1967 浏览 10 评论
3228 浏览 3 评论
2275 浏览 5 评论
819浏览 1评论
708浏览 1评论
651浏览 1评论
708浏览 0评论
605浏览 0评论
GMT+8, 2025-1-11 03:37 , Processed in 0.872177 second(s), Total 48, Slave 43 queries .
