扫一扫,分享给好友
是否可以在批处理文件中链接,以便每次执行“生成”或“干净和构建”项目命令时都运行该批处理文件?我可以手动更新MaxFrm文件,但我想知道是否有一个PSoC Creator批准的方法来执行这样的操作。
我的特定用例是确定最近的Git提交,以及源是否已经从那个状态被修改,并在构建时将其放置在conchar []中。 以上来自于百度翻译 以下为原文 Is it possible to link in a batch file so that it runs every time the "build" or "clean and build" project commands are executed? I can hack up the Makefiles manually but I'd like to know if there is a PSoC Creator Approved method to do something like this. My specific use case is to determine the most recent git commit and whether the source has been modified from that state and to place that in a const char[] at build time. |
不是来自造物主。但是您可以在命令行上运行构建(使用CyPRJMGR),在那里您可以这样做。
以上来自于百度翻译 以下为原文 Not from Creator. But you can run the build on the command line (using CyPrjMgr), there you can do that. |
我已经尝试过,但是在Bootloader中有问题,因为Bootloader显示了相对路径。 以上来自于百度翻译 以下为原文 I have tried but having issue in building bootloader since, bootloader shows relative path . |
750个成员聚集在这个小组
加入小组2055 浏览 1 评论
1811 浏览 1 评论
3622 浏览 1 评论
1747 浏览 6 评论
1499 浏览 1 评论
484浏览 2评论
339浏览 2评论
401浏览 2评论
343浏览 2评论
836浏览 2评论
GMT+8, 2024-11-10 16:07 , Processed in 0.697104 second(s), Total 47, Slave 42 queries .
