扫一扫,分享给好友
嗨亲爱的朋友
请帮助我理解: 什么条件我必须使用推拉配置输出 什么条件我必须使用开漏配置输出 谢谢 #推挽输出或开漏输出 以上来自于谷歌翻译 以下为原文 Hi dear friend Please help me to understand : What condition i have to use output with push pull configuration and what condition i have to use output with open drain configuration Thanks #push-pull-output-or-open-drain-output |
如果您不了解差异或用例,请尝试WikiPedia。
你需要开漏,你可能有多个芯片想要驱动相同的引脚,同时,例如I2C总线外设,其中引脚是有效双向的,你不需要两个高电流驱动信令高和低状态是同一时间。低状态可以由任一个驱动,因此可以被识别(即,您想要的状态与它所处的状态),并且通过限制总电流的电阻拉高,即使被一个或多个外设主动驱动为低电平也是如此。 以上来自于谷歌翻译 以下为原文 Try WikiPedia if you don't understand the difference or use cases. You'd want open-drain where you might have multiple chips wanting to drive the same pin, at the same time, for example I2C bus peripherals, where the pins are effectively bi-directional and you don't want two high current drivers signalling High and Low states are the same time. The Low state can be driven by either, and thus can be recognized (ie state you want vs state it is in), and is pulled high by a resistor that limits overall current, even when actively driven low by one or more peripherals. |
2901 浏览 1 评论
3285 浏览 1 评论
1866 浏览 1 评论
3718 浏览 6 评论
6131 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
415浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
515浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
342浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
248浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
357浏览 2评论
GMT+8, 2025-3-7 05:33 , Processed in 1.089419 second(s), Total 79, Slave 63 queries .
