嗨,我正在使用目录C:\\\\\\\\\\\\\微芯片\\\\微芯片\\\\\\\\\\\\\固件,如果我禁用“使用引导加载程序”,那么上面的应用程序固件是很好(它在EEPROM上写数据),但是当我启用bootloader时,构建应用程序链接器脚本和引导加载程序类型为USB_DEVICE,然后它不与基本引导加载程序一起工作。仅更改了函数:app.c文件:int APP_ForceBootloaderCheck(void){//对于大多数基本引导加载程序,对开关(S3)和//内存位置的检查将决定问题。//If(bSP.SwitkStaseSype=BSPwitwitsTwiteGET(BSPEX SwitCH3))(*(Uti32×T**)BooTouleRoFras-TrutGrGy地址!=0xFFFFFFFF).(1);.(0);return(0);}和system_config.h:#定义BOOTLOADER_LEGACY\#定义BOOTLOADER_BOOTLOADER_FLASH_TRIGGER_TRIGGER_TRIGGER_ADDRESS0x9D061000增加了这些行。(附上我的i2c_测试固件以构建它,成功地将其保持在“C:\\\\\\\\\\\\i2c_testi2c_test目录
以上来自于百度翻译 以下为原文 Hi, I am using basic firmware present in directory C:microchiphARMonyv1_07_01appsbootloaderbasicfirmware, and I kept my application firmware in C:microchipharmonyv1_07_01appsu***devicei2c_testi2c_testfirmware, if I disable the 'Use bootloader' then the above application firmware is working fine( its writting data on EEPROM), but when I enable use bootloader, build application linker script and bootloader type as USB_DEVICE, then its not working with basic bootloader. For customizing the bootloader, I made Few changes in basic bootloader as below: In the apps/bootloader/basic fw I only changed the function: app.c file : int APP_ForceBootloaderCheck(void) { // For most of the basic bootloaders, the check of the switch (S3) and // the memory location will decide the question. //if (BSP_SWITCH_STATE_PRESSED == BSP_SwitchStateGet(BSP_SWITCH_3)) if (*(uint32_t *)BOOTLOADER_FLASH_TRIGGER_ADDRESS != 0xFFFFFFFF) return (1); return (0); } and in system_config.h: #define BOOTLOADER_LEGACY #define BOOTLOADER_FLASH_TRIGGER_ADDRESS 0x9D061000 these lines added. (attached my i2c_test firmware to build it succesfully keep it in "C:microchipharmonyv1_07_01appsu***devicei2c_testi2c_test" directory) Attachment(s) firmware.zip (499.97 KB) - downloaded 27 times |
试试V1.09引导加载程序,看看它是否更好。
以上来自于百度翻译 以下为原文 Try the v1.09 bootloader and see if it is any better. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
486浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-21 00:48 , Processed in 0.876603 second(s), Total 43, Slave 38 queries .
