我一直在尝试设计一个简单的减法例程的16位数据路径。用一个8位的数据路径很简单,但不知怎的我不知道如何构建一个16位的数据通路。我想问题是Verilog模块的状态寄存器信号表明计算已经完成。这里有人能看出来并找出确切的问题吗?我在捆这捆。我会很感激你的回应。
Testl 1yDATAPATHY1.CYWRK.SARVEV06ZIP 241.3 K 以上来自于百度翻译 以下为原文 I have been trying to design a 16 bit Datapath for simple subtraction routine. It was pretty simple with an 8 bit datapath but somehow I can not figure out how to build a 16 bit one. I guess the problem is with status register signals from the Verilog module that indicate that calculation has been completed. Can someone here look at it and identify the exact problem? I am attaching the bundle. I will be grateful for a response. |
757个成员聚集在这个小组
加入小组2134 浏览 1 评论
1874 浏览 1 评论
3697 浏览 1 评论
1811 浏览 6 评论
1557 浏览 1 评论
755浏览 2评论
508浏览 2评论
469浏览 2评论
421浏览 2评论
1112浏览 2评论
GMT+8, 2025-2-2 02:06 , Processed in 1.150862 second(s), Total 71, Slave 55 queries .
