亲爱的朋友们,
我是柏树领域的新手。现在我应该熟悉如何尽快使用UB3 DVK。 现在我阅读了EZ-USB FX3开发工具包快速入门指南.PDF来启动我的项目,SDK已经安装成功了。 但是,我不知道如何安装DVK的驱动程序,因为当我插入UN电缆时,在我的计算机中没有通知,当我打开硬件管理中心时,在UB3树中没有其他设备。 你能告诉我如何安装FX3 DVK的驱动程序吗? 谢谢! 以上来自于百度翻译 以下为原文 Dear guys, I am a newer in cypress field . And now I should to familiar with how to use USB3 DVK as quickly as possible. Now I read the EZ-USB FX3 Development Kit quick start-guide.pdf to start my project , and the sdk have been installed in sucess. however, I do not know how to install the DVK' s driver , because when I plugin the USN cable , there are no notice in my compurer , and when I open the hardware managment center , there are no other devices in USB3 tree. Can you tell me how to install the FX3 DVK 's driver ? Thanks! |
亲爱的Manas,
如果USB插件的LED是,我已经同意,在我的PC,有“1.2 驱动”文件夹下的“程序文件 CyPress文件夹”。 但是,如果我插入或退出USB电缆,对PC的“设备管理器”没有影响,我们知道如果PC识别USB设备,“设备管理器”将刷新,如果设备插件! 我找不到关于如何使用DVK板和如何设置软件环境的指南,这样开发人员就可以开发固件、应用程序等等。所以当我打开位于你的USB套件中的Eclipse IDE并加载CysBueSub的例子时,有很多错误,似乎在SW环境中有错误! 谢谢! 以上来自于百度翻译 以下为原文 Dear Manas, If the USB plugin the LED is on , and I have confired that in my PC there are have "1.2driver" folder under the "programm filescypress folder " . But If I plugin or out the USB Cable , there are no effects on the PC 's "devices manager" , we know if the PC indentify a USB device, the "devices manager " will refresh if the device plugout ! I can not find the guide about how to use the DVK board and how to set the software environment so developers can develop the firmware .application and so on .... So when I open the eclipse IDE which located in your USBSuite and loaded the CyUSBSuite example , there are a lot of errors , It seems that there are errors in SW environment ! Thanks! |
非常感谢您更新线程。
当做, 西克里希纳。 以上来自于百度翻译 以下为原文 Thanks a lot for updating the thread. Regards, sai krishna. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 15:38 , Processed in 0.995770 second(s), Total 45, Slave 40 queries .
