嗨,
我已经测试了20多个设计用于L6926稳压器的电路板,发现一些稳压器突然进入热关断模式。我认为它是热关机,因为它试图恢复生命,加热并在一秒钟内再次关闭。在允许一定的冷却时间后芯片通电时重复相同的操作。从稳压器汲取的电流仅为几mA(最大10mA)。 在未能理解这种失败之后,我们提供了并联线性稳压器。现在,每次我们使用DC DC稳压器发生故障时,我们只需将其拆下并安装线性稳压器即可。线性稳压器从未在船上失效。所以我确信这不是负载问题。过去几个月我一直在看这些失败。 是否有任何测试方法可供您理解此故障。我尝试使用比推荐值(6.8uH)更低的电感值(4.7uH),并且故障与两个电感值一样普遍。 你能推荐一个更稳定的更换零件吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I have tested over 20+ boards that was designed to take L6926 regulators and find that some of the regulators abruptly go into thermal shutdown mode. I think it is thermal shutdown because it tries to spring back to life, heats up and shuts down again in a matter a second. The same repeats when the chip is powered up after allowing a certain cooling time. The currents being drawn from the regulators is only a few mA (10mA max). After failing to understand this failure, we made provision for a parallel linear regulator. Now, each time we have a failure with the DC DC regulator, we just remove it and mount the linear regulator. The linear regulators have never failed on board. So I am certain that this is not a load issue. I have been seeing these failures over the last several months. Is there any test method you would recommend for understanding this failure. I have tried using a lower value of inductance (4.7uH) than the recommended (6.8uH) value and the failures are just as common with both inductor values. Could you recommend a more stable replacement part? Thanks. |
嗨,
你可以发送你的设置吗? 我们需要知道Vin,Vout,电流负载以及PCB布局...... 问候 文森佐 以上来自于谷歌翻译 以下为原文 Hi, could you please send your setup? we need to know Vin, Vout, Current Load and also a PCB layout... Regards Vincenzo |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
451浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
277浏览 2评论
GMT+8, 2024-12-29 08:56 , Processed in 1.275074 second(s), Total 76, Slave 60 queries .
