您好,我想知道是否有办法使用外部触发器打开和关闭RF?
我没有特定的信号发生器,因为我的实验室有各种安捷伦信号发生器型号。 我没有看到使用外部触发来设置某个占空比和周期来打开和关闭信号发生器的输出。 有没有人有办法做到这一点? 我可以使用labview来做到这一点,但它有点慢,我想模仿实际的系统操作。 任何帮助表示赞赏,谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I am wondering if there is a way to use an external trigger to turn the RF on and off? I don't have a specific signal generator as my lab has various Agilent signal generator models. I did not see anyway to use an external trigger to setup a certain duty cycle and period to turn a signal generator's output on and off. Does anyone have a way of doing this? I can use Labview to do this, but it's a bit slow and I want to mimic the actually system operation. Any help is appreciated, thanks. |
您好,大多数安捷伦信号发生器(如PSG,MXG或ESG)都具有幅度步长或列表扫描功能。
您可以在步进扫描中编程两个振幅点。 例如,在MXG上,您将一个点设置为0 dBm,另一个点设置为-144 dBm。 然后,您可以使用点触发功能在这两个点之间切换。 此点触发事件可以来自外部TTL / CMOS触发器。 -144dBm幅度设置类似于关闭RF。希望这有帮助。 以上来自于谷歌翻译 以下为原文 Hello, Most Agilent signal generators such as the PSG, MXG, or ESG have an amplitude step or list sweep function. You can program two amplitude points in the step sweep. For example, on the MXG you set one point at 0 dBm and the other at -144 dBm. You can then use the point triggering function to toggle between these two points. This point trigger event can come from an external TTL/CMOS trigger. The -144dBm amplitude setting is similar to turning the RF off. Hope this helped. |
1285 浏览 0 评论
2373 浏览 1 评论
2192 浏览 1 评论
2064 浏览 5 评论
2948 浏览 3 评论
1108浏览 1评论
752浏览 0评论
924浏览 0评论
1287浏览 0评论
GMT+8, 2024-12-23 12:30 , Processed in 1.279659 second(s), Total 44, Slave 39 queries .
