你好,我知道这个话题以前提过,但是我还没有发现任何链接,这些链接对于计算机端用于传输.hex文件的dsPIC30F4011引导加载程序+软件来说仍然有效。有人能给我指出一个引导程序所需要的正确的方向吗?
以上来自于百度翻译 以下为原文 Hello, I know this topic has been brought up before, but I haven't found any links that are still alive for a dsPIC30F4011 bootloader + software on the computer side for transferring .hex files. Could somebody point me in the right direction for all you would need for a bootloader? |
7个回答
http://www. MICROCHEC.COM/…IP%20Ac轻松%20BooLoad也有几个附注
以上来自于百度翻译 以下为原文 http://www.microchip.com/...ip%20Easy%20Bootloader There are also several appnotes |
也许在这里(也许)http://www. McCys.com……p;utMyCase=文章
以上来自于百度翻译 以下为原文 maybe here (maybe) http://www.microchip.com/...p;utm_campaign=Article |
HTTP://www. McCHIP.COM/WavaPabeSe/AppNo.ASPX?app.=en533906如果你想要一个针对特定芯片的开箱即用的解决方案,你可以试试第三方的解决方案。
以上来自于百度翻译 以下为原文 http://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en533906 If you want an out of the box solution for a specific chip you could try the third party ones. Personally I have not found most of the Microchip Bootloaders to be unbrickable. |
你的意思是他们的引导程序会使芯片无法使用,或者使软件崩溃?有人有具体的第三方解决方案吗?我有一个在潜艇上的反相器,重新编程它是非常不切实际的。但是可靠性是非常重要的,所以片状引导加载程序也不好。
以上来自于百度翻译 以下为原文 You mean some of their bootloaders can render the chip unusable or could make the software crash? Does anyone have any specific 3rd party solutions? I have an inverter going on a submarine, and it's exceedingly impractical to reprogram it. But reliability is extremely important, so a flaky bootloader wouldn't be good either. |
然后取决于。如何触发引导加载程序?引导加载程序会在重新启动时检查GO信号吗?或者是应用程序的工作。如果是一个按钮,也可以避免积木问题。积木通常由部分应用程序负载组成。如果你有EEPROM,你可以设置一个引导负载好或者CRC,可以用来验证负载好。好的样品,但坏的最终产品。
以上来自于百度翻译 以下为原文 Then depends. How are you triggering the bootloader? Will the Bootloader check for a go signal on the reboot? Or it is the apps job. If it is a button that also avoid the bricking issue. A Brick is usually cused by a partial app load. if you have EEPROM you can set a boot load is good or CRC that can be used to verify the load is good. Microchip tends not to. OK Sample, but bad end product. |
试试这个HTTP://www. McCHIP.COM/WavaPabeSe/AppNo.ASPX?ApNote= En530200 AN1091为DSPIC30F/33 F和PIC24F/24H设备的引导加载程序
以上来自于百度翻译 以下为原文 Try this one - http://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en530200 AN1094 Bootloader for dsPIC30F/33F and PIC24F/24H Devices |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
617浏览 1评论
493浏览 1评论
347浏览 1评论
520浏览 0评论
427浏览 0评论
GMT+8, 2024-9-21 15:28 , Processed in 1.361430 second(s), Total 89, Slave 73 queries .
