大家好,我的应用程序是基于从RS232(DB9连接器)端口接收电压来操作我的设备的。众所周知,RS232根据TX引脚上的数据位产生+-15V左右。逻辑1的15V和逻辑0的+15V。我需要操作我的设备通过获得这个电压作为电源。我测试我的设备通过发送连续0到TX引脚从我的微控制器和我得到+9V通过TXout引脚的MAX232。它有足够的电流来操作我的设备,因为MAX能够提供8到10毫安的电流。这个设备工作正常,就像提供单独的VCC一样。问题是当我将数据从0提高到1时,来自同一个TX引脚的-9V会出现问题。当我将设备连接到TX PIN时,我无法控制主机设备的数据位。所以我唯一要做的就是把负电压转换成正电压。如果我能把那个-9V转换为正+9V,它将为我的设备提供连续的供电。我试过几个电压逆变器,升压集成电路,直流到直流电压转换器,但它不能像我想象的那样工作。还有,我检查了一些电路,如附图中所示的电路在我的例子中不起作用。所以,请给我一些建议。谢谢……
以上来自于百度翻译 以下为原文 Hi all, My application is based on to sink voltage from RS232 (DB9 connector) port to operate my device. As we all know RS232 generate around +-15V as per the data bits on TX pin. -15V for logic 1 and +15V for logic 0. I need to operate my device by getting this voltage as a supply. I test my device by sending the consecutive 0s to TX pin from my microcontroller and I get +9V through TXout pin of my MAX232. It had enough current to operate my device as MAX can able to supply 8 to 10 mA current. The device works fine same as by supplying separate VCC. The problem is with the -9V from the same TX pin when I raise my data to 1 instead of 0. As I connect my device to TX pin, so there is no way that I can control the data bits from the host device. So the only thing I have to do is to convert the negative voltage to positive. If somehow I can able to convert that - 9V to positive +9V it will provide the continuous supply to my device. I tried few voltage inverters, boost ICs, DC to DC voltage converters but it's not working as I aspected. Also, I go through some circuits like shown in attached figurebut not worked in my case. So, please suggest me some idea to do so. Thank you..... Attached Image(s) |
如果我没记错的话,90年代的老鼠在串口工作,为了“拾取”-12V而使用TX和另一条线,并且使用比上面显示的简单得多的一条线,将0/-12转换成+5/0(即,GND变成+5V和-12变成PIC的GND),然后您可以使用一些其他电路。转换UART信号。
以上来自于百度翻译 以下为原文 If I remember correctly, old mice from the 90s, working on the serial port, used TX and another line in order to "pick up" -12V and, using a much simpler than the one you show above, converted 0/-12 into +5/0 (i.e. the GND became +5V and -12 became PIC's GND). Then you could use some other circuitry to convert UART signals. |
在什么方面它不像你预期的那样工作?一个像你所展示的升压电路应该工作-如果元件值和额定值被正确选择。你的开关频率是多少?你的助推感应器有什么价值?你是如何计算升压电感的所需值的?你期望在连续或不连续的传导模式下操作Boost变换器吗?回答这些问题,我们将从那里开始。
以上来自于百度翻译 以下为原文 In what way is it not working as you expected? A boost circuit like the one you show should work - if the component values and ratings are chosen correctly. What is your switching frequency? What value is your boost inductor? How did you calculate the required value of the boost inductor? Are you expecting to operate the boost converter in continuous or discontinuous conduction mode? Answer those questions and we will go from there. |
5242 浏览 9 评论
2031 浏览 8 评论
1955 浏览 10 评论
3207 浏览 3 评论
2256 浏览 5 评论
778浏览 1评论
669浏览 1评论
596浏览 1评论
678浏览 0评论
577浏览 0评论
GMT+8, 2024-12-23 19:45 , Processed in 1.427136 second(s), Total 79, Slave 63 queries .
