我有一个Spartan6 LX 150T开发板。
我还有一个FMC XM 105 Rev B调试卡,它连接到开发板的JX1端口。 但是,我不知道FPGA上的哪些引脚映射到电路板上JX1 / JX2连接器上的哪些引脚。 是否有文件描述了Spartan 6 LX150t fgg676上的哪些引脚映射到电路板上JX1连接器上的哪些引脚? 请告诉我 谢谢 以上来自于谷歌翻译 以下为原文 I have a Spartan6 LX 150T development board. I also have a FMC XM 105 Rev B Debug card which is connected to the JX1 port of the Development board. However, I dont know which pins on the FPGA map onto which pins on the JX1/JX2 connector on the board. Is there a document which describes which pins on the Spartan 6 LX150t fgg676 map onto which pins on the JX1 connector on the board? Kindly let me know Thanks |
您可以使用LX150T电路板原理图。
- 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 You can use the LX150T board schematics. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
有几个演示项目,你会发现一个UCF,文档也描述了Pinout
以上来自于谷歌翻译 以下为原文 With several of the demo projects, you will find an UCF, also the docu describes the Pinout |
2306 浏览 7 评论
2716 浏览 4 评论
2197 浏览 9 评论
3278 浏览 0 评论
2351 浏览 15 评论
631浏览 1评论
1682浏览 1评论
438浏览 1评论
193浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 09:25 , Processed in 1.750501 second(s), Total 47, Slave 41 queries .
