您好!
我想把FX3固件和FPGA比特流存储在同一个SPI闪存中。然后,FX3应该从SPI启动,然后允许FPGA配置。我还希望能够使用Windows应用程序更新闪存中的数据。我知道控制中心允许编写SPI闪存,但在实际应用程序中,设备将在没有引导加载程序的情况下枚举。因此,我认为FX3固件中的代码需要注意从Windows到闪存的写入数据。或许还有别的选择? 谢谢 以上来自于百度翻译 以下为原文 Hi I want to store the FX3 firmware and FPGA bitstream in the same SPI flash. The FX3 should then boot from SPI then allow the FPGA to configure. I would also like to be able to update the data in the flash using a Windows app. I know control centre allows the SPI flash to be written, but in a real app the device would enumerate without the boot loader. So I think that code inside the FX3 firmware would need to take care of writing data from Windows to the flash memory. Or maybe there is an alternative? Thanks |
您必须在您的FX3固件中实现SPI主机。在启动FX3之后,您必须通过从串行接口(类似于SPI)配置FPGA,而在较高地址的SPI闪存内分配的比特流。使用SPI主固件,您可以用主机软件重新编程Flash。但是要注意硬件限制:如果GPIF配置为32位数据宽度,则不能使用硬件SPI。另外,你不能直接从Flash中让FPGA启动,FX3和FPGA都希望在主SPI启动模式下存储在地址0中的比特流。
以上来自于百度翻译 以下为原文 You have to implement the SPI Master in your FX3 Firmware. After booting up the FX3 you have to configure the FPGA via Slave Serial interface (similar to SPI) with the bitstream sored inside the SPI flash at higher address. With the SPI master firmware you can reprogram the FLASH with your host software. But be aware of the hardware limitation: You cannot use the hardware SPI if your GPIF is configured in 32 bit data width. Also you cannot directly let the FPGA boot from FLASH as both, the FX3 and the FPGA expects the bitstream stored at address 0 in master spi boot mode. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
274浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 19:41 , Processed in 0.758690 second(s), Total 44, Slave 39 queries .
