嗨,
我在我的设计中使用了向导生成的GTP Core。 我仅使用PLL0使用四个磁贴,每个磁贴都是相同的。 我还使用了两个用户时钟(一个用于TX(通道速度:0.64Gbps),一个用于RX(1.28Gbps))。 所以我有6个PLL。 我的GTP设计是完全对称的。 只有一个MGT_USRCLK模块的PLL(PLL0)被锁定,另一个(PLL1)被锁定一小段时间,然后再被锁定一小段时间再重新锁定一小段时间等等.... 对于瓦片PLL,仅锁定WEST PLL,并且EAST PLL具有与MGT_USRCLK PLL1相同的行为。 有人知道为什么PLL的行为就像那样???? 也许解决方案??? 谢谢, 问候, Nicolas .--------------------------------------------- Device:XC6SLX150T -2fgg676SW:ISE 13.1更新-------------------------------------------- - 以上来自于谷歌翻译 以下为原文 Hi, I use in my design the GTP Core generated by the Wizard. I use the four tiles using only the PLL0s, each tile is the same. I also used two user clocks (one for TX (lane speed: 0.64Gbps) and one for RX(1.28Gbps)). So I have 6 PLLs. My GTP design is completely symmetrical. Only one PLL (PLL0) of the MGT_USRCLK block is locked, the other (PLL1) is locked for a short time, then is unlocked for another short time before being re-locked for a short time and so on.... For the tile PLLs, only the WEST PLLs is locked and the EAST PLLs have the same behavior than the MGT_USRCLK PLL1. Does somebody have an idea why the behavior of the PLL is like that???? Maybe a solution ??? Thanks, Regards, Nicolas. --------------------------------------------- Device : XC6SLX150T-2fgg676 SW : ISE 13.1 updated --------------------------------------------- |
4个回答
哪个设备?什么软件版本?您更有可能在“连接”论坛中找到答案:http://forums.xilinx.com/t5/Connectivity/bd-p/CONN
------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 Which device? What software version? And you would be more likely to get an answer posting in the "Connectivity" forum: http://forums.xilinx.com/t5/Connectivity/bd-p/CONN ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
对不起,我忘了他们......我会把它们放在我的签名中......
设备:XC6SLX150T-2fgg676 记者:ISE 13.1已更新 我不认为这是一个连接问题,而是一个S6 PLL问题,这就是为什么我在这里发布....:smileywink:但是好的,我将把它发布在连接论坛上.... Nicolas .--------------------------------------------- Device:XC6SLX150T -2fgg676SW:ISE 13.1更新-------------------------------------------- - 以上来自于谷歌翻译 以下为原文 Sorry, I forgot them.... I will put them in my signature... Device : XC6SLX150T-2fgg676 SW : ISE 13.1 updated I don't think it's a connectivity issue but rather a S6 PLL issue, that why I post here.... :smileywink: but ok, I' m going to post it on the Connectivity Forum.... Nicolas. --------------------------------------------- Device : XC6SLX150T-2fgg676 SW : ISE 13.1 updated --------------------------------------------- |
mechouk,
你有没有想过这个? 我在Same设备和SW版本上看到了一个非常相似的问题。 人... 以上来自于谷歌翻译 以下为原文 mechouk, Did you ever get this one figured out? I am seeing a very similar issue on the Same device and SW version. Al... |
mechouk,
你有没有想到这个? 我在Same设备和SW版本上看到了一个非常相似的问题。 人... 以上来自于谷歌翻译 以下为原文 mechouk, Did you ever get this one figured out? I am seeing a very similar issue on the Same device and SW version. Al... |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1177浏览 1评论
587浏览 1评论
451浏览 1评论
2005浏览 0评论
731浏览 0评论
GMT+8, 2024-12-23 21:53 , Processed in 1.137738 second(s), Total 49, Slave 44 queries .
