嗨,
我正在以零速度控制我的PMSM。当我试图移动它的轴时,我不希望我的电机产生最大的扭矩以抵抗我的运动但是有限的一个。 经典控制一切都很顺利,但是一旦我试图限制它的扭矩 - 通过限制速度输出和Q电流PI控制器的某些较小值 - 电机开始旋转(?!)。 我真的不知道如何完成所描述的任务,通过限制PI控制器的输出来解决 有什么建议么? 提前致谢! 以上来自于谷歌翻译 以下为原文 Hi, I'm controlling my PMSM at zero speed. While I'm trying to move its shaft I don't want my motor to generate its maximum torque to resist my movement but the limited one. Everything went fine with classic control, but as soon as I tried to limit it's torque -- by limiting outputs of speed and Q-current PI controllers on some smaller values -- the motor started spinning (?!). I really have no idea how to accomplish described task, exept by limiting outputs of PI controlers Any suggestions? Thanks in advance! |
Ciao user.user
我不认为限制Q电流PI是正确的,因为你只是限制Q轴上施加的电压(也许这就是电机开始旋转的原因)。 尝试使用MC API限制速度PI的输出(这通常有效)。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao user.user I don't think that limiting the Q-current PI is correct because in that whay you are just limiting the volatge applied in the Q axis (Maybe this is the reason why the motor start to spin). Try just to limit the output of the speed PI using the MC API (this usually works). Ciao Gigi |
3005 浏览 1 评论
3329 浏览 1 评论
1908 浏览 1 评论
3767 浏览 6 评论
6187 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
76浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
87浏览 5评论
109浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
79浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
80浏览 5评论
GMT+8, 2025-4-19 11:55 , Processed in 0.690024 second(s), Total 46, Slave 40 queries .
