嗨,我想用12F675单片机驱动小型/微型电机,我试过H-Bridge电路使微型电机顺时针旋转,逆时针旋转几步,但不是全速旋转。我试过不同的开关时间,要么是连续旋转,要么是不旋转。在这个问题上请求一些帮助。
以上来自于百度翻译 以下为原文 Hi, I want to drive small / tiny motors using 12F675 MCU, i tried H-Bridge circuit to rotate tiny motor clock wise and counter clock wise few steps only not full rotation. I tried different on-time and off time, either it rotates continuously or it does not rotate. Requesting some help on this subject. |
4个回答
你应该多给点背景,也许发布你的代码和/或示意图和马达SOECs。
以上来自于百度翻译 以下为原文 You should give a little more background, maybe post your code and/or schematic and motor soecs. |
你需要电机规格,这样你就可以计算出转速和扭矩。
以上来自于百度翻译 以下为原文 You need the motor specs so that you can work out the rpm and torque. |
是步进电机吗?我假设如果你想用H桥来驱动它,在这种情况下,马达不是设计来做你所要求的。
以上来自于百度翻译 以下为原文 Is it a stepper motor? I assume not if you're trying to drive it with an H-bridge. In that case, the motor just is not designed to do what you are asking. |
5248 浏览 9 评论
2036 浏览 8 评论
1956 浏览 10 评论
3217 浏览 3 评论
2264 浏览 5 评论
781浏览 1评论
676浏览 1评论
602浏览 1评论
684浏览 0评论
581浏览 0评论
GMT+8, 2024-12-26 11:34 , Processed in 1.672351 second(s), Total 82, Slave 66 queries .
