我想以HH:MM:SS:Milliseconds格式制作时间戳....似乎没有预设功能可以做到这一点,有人可以帮助我如何做到这一点ReggardsSanjay
以上来自于谷歌翻译 以下为原文 I want to make a time stamp in the format HH:MM:SS:Milliseconds.... There seems to be no preset function to do this, can somebody help me about how to do this Regards Sanjay |
3个回答
我认为你遇到的问题是显示选项只提供秒作为最大分辨率,但时间戳值是秒数并且有一个小数部分 - 参见附带的例子。如何准确(这可能)对一些人开放
讨论! MS Windows在提供准确的时间戳方面没有很高的声誉,因此您需要谨慎对待该值。 如果需要绝对时间,请使用硬件。 以上来自于谷歌翻译 以下为原文 I think the problem you have is that the display options only offer seconds as the maximum resolution but the timestamp value is the number of seconds and has a fractional part - see the attached example. How accurate this will be is ( probably ) open to some discussion! MS Windows does not have a great reputation for providing accurate timestamps and so you need to treat the value with some caution. If absolute timing is your need, use hardware. 附件
Parse错误是由“INT64”上的VEE7.52阻塞引起的,用INT32代替修复它。
! 以上来自于谷歌翻译 以下为原文 The Parse error is caused by VEE7.52 choking on the "INT64" , substituting INT32 fixes this. ! |
@迈克尔:非常感谢@大卫:自己想出来,但无论如何,谢谢
以上来自于谷歌翻译 以下为原文 @ Michael : Many thanks @ David : Figured it out myself, but thanks anyway |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1426浏览 1评论
827浏览 0评论
1195浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 20:46 , Processed in 1.223926 second(s), Total 81, Slave 65 queries .
