对于STM8A和具有大量RAM的廉价STM8,似乎很少有评估板。基本上,STMA-Discovery是一个值得注意的例外。
我希望看到更多的STM8A板和其他至少具有4K RAM的STM8板。以下STM8变体似乎特别有趣,但还没有评估板(这意味着我既没有找到ST也没有第三方板): STM8AF6286(最便宜的STM8AF,带6K RAM) STM8S007C6(最便宜的STM8S,内存6K) STM8AL31E8A(最便宜的STM8AL,带有4K的RAM) STM8AF5268(另一个相对便宜的STM8AF,带有6K RAM) STM8S207K6(另一款相对便宜的STM8S,带有6K RAM) 有没有人知道这些板(已经可用或即将推出)? 菲利普 以上来自于谷歌翻译 以下为原文 It seems there are very few evaluation boards for the STM8A and for the cheap STM8 with lots of RAM. Basically the STMA-Discovery is the one notable exception. I'd like to see more boards for the STM8A and for other STM8 that have at least 4K of RAM. The following STM8 variants seem to be particular interesting, but don't have evaluation boards yet (which means I could find neither ST nor third-party boards): STM8AF6286 (the cheapest STM8AF with 6K of RAM) STM8S007C6 (the cheapest STM8S with 6K of RAM) STM8AL31E8A (the cheapest STM8AL with 4K of RAM) STM8AF5268 (another relatively cheap STM8AF with 6K of RAM) STM8S207K6 (another relatively cheap STM8S with 6K of RAM) Does anyone know of boards for these (either already available or upcoming)? Philipp |
为什么不查询当前可用的低成本电路板的供应商?或者拿一个并更换你喜欢的芯片?
http://www.ebay.com/itm/STM8S105K4T6-STM8S-Development-Board-Module-Core-board-MCU-Learning-Board-/222516973122?hash=item33cf0b8e42:g:sm0AAOSwZKBZHx9h 以上来自于谷歌翻译 以下为原文 Why don't you query the vendors of the currently available low cost boards? Or take one and replace the chip with one you prefer more? http://www.ebay.com/itm/STM8S105K4T6-STM8S-Development-Board-Module-Core-board-MCU-Learning-Board-/222516973122?hash=item33cf0b8e42:g:sm0AAOSwZKBZHx9h |
3007 浏览 1 评论
3331 浏览 1 评论
1909 浏览 1 评论
3767 浏览 6 评论
6187 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
77浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
88浏览 5评论
112浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
79浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
82浏览 5评论
GMT+8, 2025-4-20 14:50 , Processed in 0.546977 second(s), Total 44, Slave 39 queries .
