嗨,伙计们,
我在Xilinx FPGA开发板上开发的,上面有CY7C6300板。我想在PC机和板卡之间有USB接口。当我把USB电缆插入PC机时,我得到了CyPress EZ-OTG的新硬件向导。我在网上寻找合适的司机,但仍然徒劳无功。有人能给我这个CY7C6300的司机吗?很多THKS。 PN 以上来自于百度翻译 以下为原文 Hi guys, I'm developing on Xilinx FPGA development board which has CY7C67300 on board. And i want to have USB interface between PC and the board. When i plug in the USB cable to PC, I'm getting new hardware wizard for Cypress EZ-OTG. I look for suitable driver on internet but still in vain. Can someone please pass me driver for this CY7C67300? Many Thks. PN |
5个回答
你好,
我现在在你的位置,找到一个CY7C6300司机连接到FPGA板ML402。 你找到解决问题的办法了吗?请帮助 以上来自于百度翻译 以下为原文 hi, i am now in ur position, finding a driver for cy7c67300 to connect to fpga board ml402. did u find a solution to the problem? please help |
不确定你是否还在寻找驱动程序,但是你可以通过EZHEngestDevelopment套件下载它们(我想它的编号是3663)。有一个安装程序,将.sys和.INF文件放在适当的位置。
HTTP://www. CyPress?COM/?RID=14316 下载DeV工具包的CDyROM映像并运行安装程序。 以上来自于百度翻译 以下为原文 Not sure if you are still looking for drivers, but you can download them through the EZ_HOST development kit (i think it's numbered 3663). there's a installation program which drops the .sys and .inf files in the proper place. http://www.cypress.com/?rID=14316 download the CD_ROM image for the dev kit and run the setup program. |
我有同样的麻烦,但AN3663驱动程序不工作(Windows 7)。我有一个自定义板与CY7C67 300上。我把USB电缆连接到端口2A,并把它插入我的PC。它列举了CyPress EZ-OTG,但不能自动安装驱动程序。我以前安装了AN3663安装程序,所以我导航到C:CyPress USB OTG主机驱动程序,找到Cyf.DEF.IF(10/28/2004)和CysBGEn.SIS(11/26/2002)。从设备管理器中,我尝试更新驱动程序并指向该文件夹。但是我得到了错误信息“Windows找不到你的设备的驱动程序软件。”我正在运行Windows 7 SP1(64位)。
以上来自于百度翻译 以下为原文 I'm having the same trouble, but the AN3663 driver doesn't work (Windows 7). I have a custom board with the CY7C67300 on it. I connected a USB cable to port 2A and plugged it into my PC. It enumerates as CYPRESS EZ-OTG, but can't automatically install a driver. I had previously installed the AN3663 setup, so I navigated to c:CypressUSBOTG-HostDrivers and found cy_def.inf (10/28/2004) and cyu***gen.sys (11/26/2002). From the device manager, I try to update the driver and point at this folder. But I get the error message "Windows could not find driver software for your device." I'm running Windows 7 SP1 (64-bit). |
我需要和CY7C6300控制器一起工作。我是这个控制器的新用户。我将如何为这个控制器编写Bootloader程序,以及如何将Bootloader代码构建到EEPROP中。请任何人给我提建议。
以上来自于百度翻译 以下为原文 hai...i need to work with cy7c67300 controller.iam a new user for this controller.how would i write bootloader program for this controller and how would i built the bootloader code into eeprom.please anyone can give me suggestion. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 13:46 , Processed in 0.821131 second(s), Total 52, Slave 47 queries .
