你好,
我试图通过使用RS232的桥接控制面板将PSoC3连接到我的PC。据我所知,UART配置正确,以及控制面板。我已经通过超级终端确认了数据对PC的控制。控制面板说它是连接的,但是当我尝试执行一个重复命令时,什么也没有发生。我见过一个计数回来一次或两次,但没有数据显示通过面板。请与我分享你的智慧。 沃尔特 测试程序 1.8兆字节 以上来自于百度翻译 以下为原文 Hello, I am trying to connect a PSoC3 to my PC through the Bridge Control Panel using RS232. As far as I can tell the UART is configured correctly as well as the control panel. I have confirmed through hyperterminal the data is ariving to the PC. The Control Panel says it is connected but when I try to execute a Repeat command nothing happens. I have seen a single count come back once or twice now but no data is ever displayed through the panel. Please share any wisdom you have with me. -Walt
5个回答
AFIK桥控制面板设计用于CY32 40 UB-I2C桥套件,它使用PSoC1芯片(CY8C24894)。你的PSoC3编程完全一样吗?否则,难怪桥控制面板不与您的PSoC3…
以上来自于百度翻译 以下为原文 AFAIK the bridge control panel is designed for use with the CY3240 USB-I2C Bridge Kit, which uses a PSoC1 chip (CY8C24894). Did you program your PSoC3 to behave exactly the same? Otherwise it seems no wonder that the bridge control panel doesn't talk with your PSoC3... |
忘了我的最后一篇文章,我只是浏览了一下文档,发现它不仅仅是这个工具包,而且是有用的。
但是,你是否遵循了其中一个例子来验证你的基本设置(ND硬件)是否正常?例如“从桥控制面板1.8文档”中的“RX8X Sunx示例”?这样你就可以验证你的设置,以及你需要采取的步骤(从文档中判断,这看起来不那么简单)。 最后但并非最不重要的,你也可以尝试安装一个COM端口嗅探器看数据通过它,也许这也有助于… 以上来自于百度翻译 以下为原文 Forget my last post, I just read through the documentation and saw that it indeed is useful for more than just this kit. But still: did you follow one of the examples to verify that your basic setup (nd hardware) is OK? E.g. the "RX8_Sin_X Example for ComPort" from the Bridge Control panel 1.8 documentation? That way you could verify your setup, and the steps you need to take (it doesn't seem so simple judging from the documention). Last but not least, you can also try to install a COM-Port-Sniffer to look at the data going through it, maybe that helps too... |
你好,我需要知道如何得到布里奇控制面板?
以上来自于百度翻译 以下为原文 Hello, I need know how get the Brige Control Panel? |
欢迎来到论坛。
当你有CyPress创建者安装(完全)桥控制面板将安装在开始& GT;柏树。 鲍勃 以上来自于百度翻译 以下为原文 Welcome in the forum. When you have Cypress Creator installed (completely) the bridge control panel will be installed under Start -> Cypress. Bob |
您好!
我的桥牌控制面板是固定的,我已经做了修理安装,但是桥控制面板没有安装。请指示我另一个安装的链接。 谢谢 以上来自于百度翻译 以下为原文 Hi My Bridge control panel is unistalled, I have done a repair installation, but the bridge control panel is not installed. Please direct me to another link for installation. Thanks |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 15:34 , Processed in 1.007572 second(s), Total 84, Slave 68 queries .
