扫一扫,分享给好友
升级到PSoC Creator 2.2和重建项目后,当尝试对设备进行编程时,得到以下消息:
“该设备已被识别,但PSoC Creator此时不支持使用它。” 这个芯片停止了吗? 以上来自于百度翻译 以下为原文 After upgrading to PSoC Creator 2.2 and rebuilding a project I get the following message when attempting to program the device: "This device was recognized, but PSoC Creator does not support using it at this time" is this chip discontinued? |
7个回答
他们CyPress网站不知道这一部分:HTTP://www. CyPress?APP= Search and Search Type=Po.&关键字:CY8C38 66 A&P;提交关键字。x=0和提交关键字。y=0。
它是从哪里来的(我甚至找不到谷歌……)? 以上来自于百度翻译 以下为原文 They Cypress website doesn't know about this part: http://www.cypress.com/?app=search&searchType=part&keywords=CY8C3866A&submit-keywords.x=0&submit-keywords.y=0 Where does it come from (I cannot even find it with Google...)? |
我从来没有见过一包。它不是CY8C366AXI吗?
以上来自于百度翻译 以下为原文 I have never seen AY1 packages. Isn't it rather CY8C3866-AXI ? |
我创建了一个新项目,从设备选择菜单中选择CY8C3666 AXI-040,编译程序,连接开发系统A,D得到相同的消息。认可但不支持。别担心。我会找到另一种方法去做我需要做的事情。谢谢你的尝试。
以上来自于百度翻译 以下为原文 I created a new project, selected CY8C3666AXI-040 from the deviceselect menu, compiled the program, connected the development system a,d got the same message. Recognized but not supported. Don't worry about it. I'll find another way to do what I need done. Thanks for trying. |
哦,PSOC3 ES2硅从一段时间以来就不受创建者的支持(自2.1版以来)。PSOC3从一段时间就开始生产了,所以更换程序已经结束(否则你可以换一个新的)。所以也许你应该问问你当地的柏树联络人寻求帮助。或者你需要回到一个更老的创造者版本2仍然有效。
以上来自于百度翻译 以下为原文 Oh, PSoC3 ES2 silicon is not supported in Creator since a while (Since version 2.1). PSoC3 is in production since a a while, so the replacement program has been ended (otherwise you could have exchanged your kit with a newer one). So maybe you should ask your local Cypress contact for help. Or you need to go back to an older Creator version - 2.0 should still work. |
CY8C3666 AXI-040ES2中的ES是工程样品,早就停止了。PSOC3ES设备支持已从创建者移除,因为VILION 2.1 PSOC5ES支持在创建者2.2中被移除。
你可以下载一个旧版本的创建者来编译你的项目,但是你最好能得到新的硅并把你的项目移动到新的设备。 以上来自于百度翻译 以下为原文 The ES in CY8C3866AXI-040ES2 means engineering sample and it was discontinued long time ago. PSOC3 ES device support has been removed from Creator since verion 2.1 PSOC5 ES support was removed in Creator 2.2 You could download an older version of Creator to compile your project but you would be better off getting new silicon and moving your project to the new device. |
创建者2.2仍然支持PSOC5 CY8C5688 AXI-060ES1,这是第一个001和050个套件中的一部分。所有其他ES1部分被删除,但我希望这一个将得到支持一段时间…
以上来自于百度翻译 以下为原文 Creator 2.2 still supports the PSoC5 CY8C5588AXI-060ES1 which is the part which was on the first -001 and -050 kits. All other ES1 parts are removed, but I hope this one will be supported for a while... |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1828 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
534浏览 2评论
482浏览 2评论
443浏览 2评论
1138浏览 2评论
GMT+8, 2025-2-23 15:35 , Processed in 0.882910 second(s), Total 57, Slave 51 queries .
