STM32的定时器输出比较实验,计数值比比较捕获定时器值小,能触发中断?应该不能啊
现在我的程序一直在触发中断,不知道为什么 没有开溢出中断 #include "stm32f10x.h" void RCC_Configuration(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD,ENABLE); //外设要开复用时钟? RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; //LED0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_SetBits(GPIOA,GPIO_Pin_8); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOD,&GPIO_InitStructure); GPIO_SetBits(GPIOD,GPIO_Pin_2); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //TIM2的CH1是PA0的复用功能 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA,&GPIO_InitStructure); } void TIMx_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; //时基单元初始化 TIM_TimeBaseStructure.TIM_Period = 8000; //计数值8000 TIM_TimeBaseStructure.TIM_Prescaler = 999; //8000000/1000=8000Hz,周期为1/8000,计数器周期为1s TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Active; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 15100; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM2,&TIM_OCInitStructure); TIM_ITConfig(TIM2,TIM_IT_CC1,ENABLE); TIM_ClearITPendingBit(TIM2,TIM_IT_CC1); //使能输出比较中断 TIM_Cmd(TIM2,ENABLE); } void Delay(vu32 times) { for(;times!=0;times--); } void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); NVIC_Init(&NVIC_InitStructure); } int main(void) { RCC_Configuration(); GPIO_Configuration(); TIMx_Configuration(); NVIC_Configuration(); while(1) { GPIO_ResetBits(GPIOA,GPIO_Pin_8); Delay(100000); GPIO_SetBits(GPIOA,GPIO_Pin_8); Delay(100000); } } void TIM2_IRQHandler(void) { if(TIM_GetITStatus(TIM2, TIM_IT_CC1) == SET) { TIM_ClearITPendingBit(TIM2,TIM_IT_CC1); TIM_SetCounter(TIM2,0x0000); GPIO_ResetBits(GPIOD,GPIO_Pin_2); Delay(1000000); GPIO_SetBits(GPIOD,GPIO_Pin_2); } } |
我又改动了一下中断函数,得到清晰的结果
void TIM2_IRQHandler(void) { if(TIM_GetITStatus(TIM2, TIM_IT_CC1) == SET)//比较捕获中断 { TIM_ClearITPendingBit(TIM2,TIM_IT_CC1);//清中断 GPIO_ResetBits(GPIOA,GPIO_Pin_8); //红灯亮 if(TIM_GetCounter(TIM2) ==0) //计数值为零 { TIM_SetCounter(TIM2,0x0000); //清零计数值 GPIO_ResetBits(GPIOD,GPIO_Pin_2); //黄灯亮 Delay(1000000); GPIO_SetBits(GPIOD,GPIO_Pin_2); } } } 当计数值为零时,黄灯能够亮灭。计数值小于比较捕获寄存器值,应该不会触发中断,但触发中断了,而且是在计数值为零时,实在搞不懂了, |
多看几遍手册,就懂了.
2000 浏览 1 评论
1782 浏览 1 评论
1248 浏览 2 评论
825 浏览 2 评论
1800 浏览 2 评论
2032浏览 9评论
942浏览 4评论
340浏览 3评论
684浏览 3评论
668浏览 3评论
GMT+8, 2025-3-7 09:11 , Processed in 0.768110 second(s), Total 45, Slave 40 queries .
