您好!
我有关于从属批量模式的缓冲区工作的查询。 如果我已经设置了从FIFO 512x4四路,缓冲区是如何工作的? 也许FX2LP看起来有4个缓冲区。 因此,这有任何顺序写入或读取缓冲区? 我还能知道读写中缓冲区的切换时间吗? 以上来自于百度翻译 以下为原文 Hi I have query about buffers work of slave bulk mode. If i have set slave fifo 512x4 quad, how are buffers work? Maybe it seems like that fx2lp have 4buffers. So Have this any order in write or read to buffer? Also can i know about buffers switching time in read or write? |
嗨,假设你在FX2LP中配置了端点内存到512×4。这样,你就分配了2KB的内存,让你用512配置你的自动配置寄存器。然后只要512字节的数据已经写入FX2LP FIFO,它将自动提交到USB主机。连接到FX2LP的FPGA开始将数据写入下一个内存位置。再次,一旦512字节写入,它将致力于USB主机。这个过程将持续到第四个512字节块被填充。一旦做到这一点,它将开始写从第一个,如果它已经提交到USB主机。在FX2LP的情况下,没有缓冲切换延迟。谢谢,赛克利纳。
以上来自于百度翻译 以下为原文 Hi, Let say you configured endpoint memory in FX2LP to 512 * 4. This way you are allocating 2KB of memory and let say you configured AUTOCONFIG registers with 512. Then as soon as 512 bytes of data has been written into FX2LP FIFO, it will be automatically committed to the USB host. FPGA connected to FX2LP starts writing data into next memory location. Again once 512 bytes are written it will be committed to USB host. This process will continue till 4th 512 bytes block gets filled. Once that is done it will start writing from the 1st one if it is already committed to USB host. There is no buffer switching delay in case of FX2LP. Thanks, sai krishna. |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
570浏览 2评论
423浏览 2评论
437浏览 2评论
384浏览 2评论
915浏览 2评论
GMT+8, 2024-12-24 07:39 , Processed in 0.868204 second(s), Total 42, Slave 37 queries .
