喜
我正在尝试使用LN298和ATMEL微控制器驱动直流电机(20v),当我尝试单独使用LN298(没有微控制器)驱动直流电机时,它运行良好。 当我单独尝试微控制器时,它会提供正确的输出(在LED上进行测试) 但是当我尝试将微控制器直接连接到LN298时问题出现了。 LN298从微控制器获取其第一个状态,然后微控制器停止(我之后没有响应任何事情) 我试图把ULN2003放在微控制器和LN298之间, 我还试图在它们之间装一个逆变器, 我也尝试过晶体管和二极管,但每次微控制器在向LN298提供第一个输出后停止响应时都会出现同样的问题 任何人都可以帮忙... 以上来自于谷歌翻译 以下为原文 hi, i am trying to drive a dc motor (20v) using LN298 and ATMEL microcontroller, when i try to drive the dc motor with LN298 alone (without microcontroller) it works good. and when i try the microcontroller alone it gives the right output (testing on leds) but the problem apears when i try to connect the microcontroller directly to the LN298. the LN298 takes its first state from the microcontroller and then the microcontroller stops (i doesnt respond to anything after that) i tried to put ULN2003 between the microcontroller and LN298, i also tried to put an inverter between them, i also tried transistors and diodes but the same problem appears each time the microcontroller stops responding after it gives the first output to LN298 can any one help please... |
检查你的电源
看来你没有自己的力量 正在使用Batterys ?? Vs = 20V MOTOR VOLTAGE VSS = 5V TTL / CMOS [此消息由:Cortex于05-04-2005 00:30编辑] 以上来自于谷歌翻译 以下为原文 check your power supply it seem that u don't have egnouh power are using Batterys ?? the Vs = 20V MOTOR VOLTAGE the VSS = 5V TTL/CMOS [ This message was edited by: Cortex on 05-04-2005 00:30 ] |
2418 浏览 1 评论
3134 浏览 1 评论
1704 浏览 1 评论
3517 浏览 6 评论
5875 浏览 21 评论
861浏览 4评论
1236浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
505浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1218浏览 3评论
1273浏览 3评论
GMT+8, 2024-9-21 18:51 , Processed in 1.122344 second(s), Total 80, Slave 64 queries .
