是的,我知道它不是主题(但它连接到PIC)。也不是一个成本效益高的解决方案。但它已经在PCB上了。它的最大电流为40Ma。我需要60至90毫安。我正在寻找一个下降的替代品。
以上来自于百度翻译 以下为原文 Yes I know it is off topic (but it is connected to a PIC). And Not a cost effective solution. But it is already on the PCB. It has a max current of 40ma. I need 60 to 90ma. I am looking for a drop-in replacement.. |
4个回答
检查驾驶员的着陆页。他们有一个应用笔记,告诉你如何连接到外部FET驱动更多的电流。
以上来自于百度翻译 以下为原文 Check their landing page for the driver. They have an app note that shows you how to connect to external FET to drive more current. |
考虑到它的成本,在增加成本之前,我会先使用PIC。如果可能的话,目标是在没有板旋转的情况下使LED发光。
以上来自于百度翻译 以下为原文 Considering what it costs, I would go with a PIC before I added more cost to it. The goal is to brighten up the LEDs without a board spin, if posible |
一次性产品,还是商业产品?当我读它时,功耗是问题。你可以尝试散热芯片,并改变ISET电阻器,以推动更多的电流通过现有的芯片。
以上来自于百度翻译 以下为原文 One-off, or commercial product? As I read it, power dissipation is the problem. You could try heatsinking the chip, and changing the ISET resistor to push a bit more current through the existing chip. |
这是一个商业产品的预生产运行。现在要重新设计(到现在为止)。我很惊讶,没有人把这个老的基于Intersil的芯片弄掉了,而且它的价格是多么昂贵。
以上来自于百度翻译 以下为原文 It is a a Pre-production Run for a commercial product. It is to late to to redesign (for Now). I am surprised that no one has juiced this old Intersil based Chip, and how expensive it is |
5250 浏览 9 评论
2037 浏览 8 评论
1958 浏览 10 评论
3218 浏览 3 评论
2266 浏览 5 评论
788浏览 1评论
680浏览 1评论
609浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-28 22:56 , Processed in 1.299219 second(s), Total 82, Slave 66 queries .
