海都。我用C语言编写了一个简单的内部EEPROM程序,使用MPLAB和高威廉希尔官方网站
C编译器。在PIC16F877 A中,EEPROM为256字节。这是一个简单的程序来存储一些值在寄存器和检查出来。如果它是正确的眨眼LED。但是错误发生了…我收到的错误是“下列内存区域未能正确编程:EdAdA内存地址:0000000 2预期值:00000000接收值:000000 FF编程失败”,虽然我收到错误,但输出正确。我不明白。在地址二中存储0(零)是错误的吗?有人给我解释一下…我在这里附上下面的源代码…
以上来自于百度翻译 以下为原文 Hai all. I wrote a simple program for internal EEPROM in C language using MPLAB with HI-TECH C compiler. In PIC16F877A EEPROM is 256 bytes. It's a simple program to store some value in Register & check it out .. If it's correct blink Led. But the error occurred.... The error which i received is "The following memory regions failed to program correctly: EEData Memory Address: 00000002 Expected Value: 00000000 Received Value: 000000ff Programming failed" Though i received the error but the output came correctly.. I don't understand. Is it anything wrong to store 0 (Zero) in address two. Anyone give me the explanation to me..... I here attach the source code below..... #include __CONFIG(0x3F3A); #define _XTAL_FREQ 20000000 int a; void main() { PORTD=0x00; TRISD=0x00; eeprom_write(2,0); a=eeprom_read(2); while(1) { if(a==0) { RD0=1; } else { RD0=0; } } } |
在程序的开始时添加一个延迟。您的代码在编程周期和验证周期之间短暂地运行,因此在程序员试图验证它写的内容之前,您要进入并更改EEPROM的内容。
以上来自于百度翻译 以下为原文 Add a delay to the start of your program. Your code is running briefly between the programming cycle and the verify cycle, so you are getting in and changing the contents of the EEPROM before the prgrammer tries to verify what it wrote. |
5243 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
3208 浏览 3 评论
2258 浏览 5 评论
778浏览 1评论
669浏览 1评论
597浏览 1评论
679浏览 0评论
577浏览 0评论
GMT+8, 2024-12-24 08:27 , Processed in 1.167835 second(s), Total 46, Slave 40 queries .
