我们在PIC32家族中有外部数据存储器读(RD×)、写(WR)吗?我现在有一个已经在ARM中实现的设计,想切换到PIC32,想知道PIC32中是否有一个相当于PIN的PIN?问候,莫
以上来自于百度翻译 以下为原文 Do we have an external data memory read (rd#), write (wr#) strobe in PIC32 family? I currently have a design already implemented in ARM and would like to switch to PIC32 and was wondering if there's an equivalent pin for them in PIC32? Regards, Mo |
3个回答
嗨,PIC32MX设备有一个“并行主端口”,有8或16条数据线,12或16条地址线,这取决于封装上的引脚数量。它们有RD和WR选通线,可用于访问外部闪存或SRAM存储器,但更常用于接口显示设备或显示控制器。在PIC32 MX中,它们可用于在外部和内部RAM之间传输数据,但不能用于直接访问外部存储器。作为内存映射存储器,PIC32 MZ器件还具有“多达24条地址线”的“外部总线接口”。它们可以用来建立对映射到一部分内存地址的外部内存的访问,也可以映射为程序内存来执行代码。
以上来自于百度翻译 以下为原文 Hi, PIC32MX devices have a "Parallel Master Port" with 8 or 16 data lines, and 12 or 16 address lines, depending on number of pins on the package. They have RD and WR strobe lines, and may be used to access external Flash or SRAM memory, but are more often used to interface a display device or display controller. In PIC32 MX they may be used to transfer data between external and internal RAM, but cannot be used to access external memory directly as memory mapped storage. PIC32MZ devices also have "External Bus Interface" with up to 24 address lines. They may be used to set up access to external memory mapped to a part of memory addresses, and may also be mapped as Program memory to execute code. Regards, Mysil |
谢谢,你有PIC32 MX设备中最大的PMP数据速率吗?问候,莫
以上来自于百度翻译 以下为原文 Thanks, Do you have a number for maximum PMP data rate in PIC32MX devices? Regards, Mo |
5306 浏览 9 评论
2070 浏览 8 评论
1973 浏览 10 评论
3243 浏览 3 评论
2279 浏览 5 评论
828浏览 1评论
720浏览 1评论
664浏览 1评论
716浏览 0评论
616浏览 0评论
GMT+8, 2025-1-26 15:14 , Processed in 0.968147 second(s), Total 46, Slave 40 queries .
