ReBud/CLAAD和构建更改我的十六进制文件…
并且使用不同的CurATO和所有相同版本的组件提供不同的HEX文件????/ 以上来自于百度翻译 以下为原文 Does rebuld/ clead and build change my hex file.... and also Using different creatos with all the same version of components provide with different hex files???/ |
我不确定,如果编译的日期和时间是否包含在HEX文件中,因为有允许的注释。
重建项目可能会导致不同的产出,因为通常没有规则的布局优化阶段和类似的事情。特别是因为有使用蒙特卡罗算法的优化方法,正如名字所说的,使用的是随机数。 鲍勃 以上来自于百度翻译 以下为原文 I am not sure about if for instance date and time of compilation is included into a hex-file since there are comments allowed. Rebuilding a project may of course lead to different outputs since there are often no regulations of the order of placements optimization stages and similar things. Especially because there are optimization methods using monte-carlo-algorithms which -as the name says- are using random numbers. Bob |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 11:17 , Processed in 1.051760 second(s), Total 44, Slave 39 queries .
