我简要地看了一个头文件,它有一个分开的代码为PSoC4!!!!
谁能说出这个新产品的特点是什么? 以上来自于百度翻译 以下为原文 I recenttly had alook at one of the header file and it had a seperate code for PSoC4!!! Can any one say as to what are the features of this new product? |
8个回答
是的,PSoC4会来的。塞浦路斯对它的特性保持了一些犹豫,但我怀疑它的核心将是一个手臂M0来保持它的便宜。有一些视频比较了8051内核和ARM M0,而不是皮质M3,我怀疑这背后的原因。哪种模拟和数字硬件模块即将到来?让我猜猜:美国太空站的概念和结构是成功的,所以“永远不要改变获胜的队伍”。
鲍勃 以上来自于百度翻译 以下为原文 Yes, a PSoC4 will come. Cypress keeps a bit qiuet about its features, but I suspect that the core will be an ARM M0 to keep it cheap. There are some videos which compare the 8051 core to ARM M0 and not to Cortex M3, I suspect a reason behind that. Which analog and digital hardware modules are to come? Let me guess: the concept and the structure of USBs is successful, so "never change a winning team". Bob |
…还有一个:一个近一年的线索,讨论同一个主题。现在我们可以想象,至少需要一年,直到有PSOC4的工程样本(微笑)。
HTTP://www. CyPress?COM/?APP =论坛和RID=57268 鲍勃 以上来自于百度翻译 以下为原文 ... and one more: here is a link to a nearly one-year old thread discussing the very same theme. Now we can imagine that it will take at least anothere year until there are engeneering samples of a PSoC4 (Smile) http://www.cypress.com/?app=forum&rID=57268 Bob |
我们已经对PSoC4特别关注了一年了。一个PSoC今天的视频暗示我们将得到一个CordX-M0 PSoC,所以我们推测它将是传奇的PSoC4。不过,目前还没有官方消息。
以上来自于百度翻译 以下为原文 We have been especulating about PSOC4 for about a year already. A PSOC today video hinted that we were going to get a Cortex-m0 PSOC so we asumed it would be the legendary PSOC4. Still, there are no official news about it tho. |
投机已经结束:
San若泽,Calif.,2013年3月20日-赛普拉斯半导体公司(NASDAQ:CY)今天推出了PSoC®4可编程系统片上架构,它结合了赛普拉斯的最好的PSoC模拟和数字织物和业界领先的CopSunch®电容触摸威廉希尔官方网站 与ARM®的POWER效率皮质μ-M0核。 在www. CyPress .COM/GO/PSoC4中阅读更多信息 谢谢! 吉姆 以上来自于百度翻译 以下为原文 Speculation is over: SAN JOSE, Calif., March 20, 2013 – Cypress Semiconductor Corp. (NASDAQ: CY) today unveiled the PSoC® 4 programmable system-on-chip architecture, which combines Cypress’s best-in-class PSoC analog and digital fabric and industry-leading CapSense® capacitive touch technology with ARM®’s power-efficient Cortex™-M0 core. Read more at www.cypress.com/go/PSoC4 thanks! Jim |
我刚刚阅读了关于www.
这是一个CordX-M0。它是低功耗的。 以上来自于百度翻译 以下为原文 I've just read the news on www.embedded.com it is a Cortex-M0. and it comes with low power consumtion. |
感谢让社区知道PSoC 4将是真实的。当我看你提到的网站时,数据明显缺乏。
这里是什么(类似) 12位模数转换器 运算放大器,比较器,IDAC,精密电压基准。 -------- “创新”措辞 “停止模式只消耗20 NA,同时仍保持唤醒的能力,由极低功率保持睡眠模式补充,只吸引150 NA而不干扰SRAM数据” ?在不干扰SRAM数据的情况下?猜想它意味着在充分保留SRAM内容的同时 ---------- 从建筑简报。 “大多数可重新配置的ARM CORTEX-M0”OOPS - CyPress拥有一个架构许可证来重新配置核心吗? 在等待数天之后,是否还有更多的数据要消化,我有点失望什么(不)传达关于PSoC 4。 失踪: -包裹? PSoC 4是否升级到PSoC 3?- CPU指示“是”8位-gt;32位,ADC指示20位-gt;12位; -记忆?32 K/8K?64K/8K?128K/12K与市场上其他M0设备一样? -马克斯频率?PSoC不是关于高频的,他承认,在PSoC 4的计算性能中可以使用哪些算法仍然是非常有趣的。 -低功耗模式下的电流消耗是重要的,然而,有时需要激活设备-激活模式下的消耗? -是否有一个用于创建者2.2的开关来完全激活PSoC 4?还是我们在等待创造者2.3(3)? -视频包括一个UBB-FS块(39秒和1∶15分钟),架构概要没有-是什么? 塞浦路斯宣布一个新的设备,新闻发布的信息很少,这是不寻常的。关于PSoC 4的谣言已经在这个论坛上逗留了一年多,一定有一些类似于PrL的东西。数据表! 请张贴! 以上来自于百度翻译 以下为原文 Thanks for letting the community know that PSoC 4 will be real. When I looked at the website you mentioned, there was an obvious lack of data. Here is what I found (and like) 12-bit ADC Op-Amps, Comparators, IDACs, precision voltage reference. -------- "Innovative" wording " stop mode consuming only 20 nA while still retaining its ability to wake up, complemented by an extremely low-power retention sleep mode that draws only 150 nA without disturbing SRAM data" ? without disturbing SRAM data ? Guess it means while fully retaining SRAM content --------- From the architecture brief. "Most Reconfigurable ARM Cortex-M0" Oops - Does Cypress own an architecture license to reconfigure the core? After waiting a few days whether there is going to be more data to digest, I am somewhat disappointed what is (not) communicated about PSoC 4 Missing: - packages? - is the PSoC 4 an upgrade to PSoC 3? - The CPU indicates yes 8-bit -> 32-bit, The ADC indicates otherwise 20-bit -> 12-bit? - memory? 32k/8k ? 64k/8k? 128K/12k like other M0 devices on the market? - Max frequency? PSoC is not about high frequency, acknowledge that, it is still very interesting what algorithms can be used within the computing performance of the PSoC 4 - current consumption in low power modes are important, however, sometimes the device needs to be activated - consumption in active mode? - is there a switch for Creator 2.2 to fully activate PSoC 4? - or are we waiting for Creator 2.3 (3.0)? - the video included a USB-FS block (39sec and 1:15min), the architecture brief does not - what is it? It is unusual for Cypress to announce a new device with so little information accompanying the press release. Rumors about PSoC 4 have been lingering in this forum for more than a year, there must be something like a prel. data sheet! Please post it! |
您提到的降低ADC分辨率来自于PSoC4附带一个SAR ADC,它运行在1MSPS(像PSoC5LP)。PSCO3没有DelSig ADClike。但是,正如我们在另一个线程中所学到的,我们可以用可用的组件和UDB构建一个线程。或者你只是使用过采样…
以上来自于百度翻译 以下为原文 The reduced ADC resolution you mentioned comes from the fact that the PSoC4 comes with a SAR ADC, which runs at 1MSpS (like the PSoC5LP). There is just no DelSig-ADC like the PSoC3 has. But as we learned in another thread here, one could build one with theavailable components and the UDB. Or you just use oversampling... |
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1600 浏览 1 评论
978浏览 2评论
663浏览 2评论
511浏览 2评论
478浏览 2评论
1350浏览 2评论
GMT+8, 2025-4-6 03:37 , Processed in 1.131355 second(s), Total 58, Slave 52 queries .
