我如何在spartan 3e中设置hswap引脚...实际上我没有在spartan 3e套件中找到像hswap这样的引脚......它是否作为软件控制?
在主模式设置期间,建议将hswap引脚配置为低电平... 以上来自于谷歌翻译 以下为原文 how i set hswap pin in spartan 3e..actually i did not find any pin like hswap in spartan 3e kit...is it control as software?. during master mode setup it will be suggest to configure the hswap pin low... |
将此引脚连接到GND,然后在配置过程中所有GPIO将通过内部上拉电阻上拉。
该引脚为高电平将所有GPIO置于3态。 -------------------------------------------------- -------------------------------------------------- --------不要忘记回复,kudo,并接受为解决方案.---------------------------- -------------------------------------------------- --------------------------- 以上来自于谷歌翻译 以下为原文 Connect this pin to GND and then all the GPIOs during configuration process will be pulled up through internal pull-up resistors. This pin being High places all the GPIOs in 3-state.------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. --------------------------------------------------------------------------------------------------------- |
2468 浏览 7 评论
2855 浏览 4 评论
2317 浏览 9 评论
3400 浏览 0 评论
2498 浏览 15 评论
2107浏览 1评论
640浏览 1评论
498浏览 1评论
2047浏览 0评论
778浏览 0评论
GMT+8, 2025-1-31 13:54 , Processed in 1.359446 second(s), Total 42, Slave 37 queries .
