你好,
我想用DMA来控制一些GPIO的状态。软件应将数组的条目写入PGPDO [0]寄存器。在那种情况下,我写了一个小的演示程序。 outputArray是uint16_t,包含256个元素。每个元素代表8个GPIO引脚的状态。软件应将这些元素循环写入PGPDO [0]寄存器,但它不起作用。配置看起来像这样: 当我希望DMA传输尽可能快地连续运行时,有人能告诉我在配置中需要更改的内容吗? 最好的祝福, 帕特里克 以上来自于谷歌翻译 以下为原文 Hello, I would like to use DMA to control the states of some GPIOs. The software should write the entries of an array to the PGPDO[0] register. For that case, I wrote a small demo program. The outputArray is uint16_t and contains 256 elements. Each element stands for a state of 8 GPIO pins. The software should write these elements circular to the PGPDO[0] register, but it doesn´t work. The configuration looks like that:
Can anybody tell me what I have to change in my configuration when I want the DMA transfer to run continuously as fast as possible? Best regards, Patrik |
你好,
我发现了这个问题。我认为这是错误的通道配置和DMA_MUX配置的组合。以下代码使我可以将数组元素连续传输到PGPDO端口。 DAC2Table包含128个16位元素。 我还能够使用PIT和触发功能触发数组元素的传输。不过,我在理解如何将DMA与其他模块一起使用时又遇到了一些问题。 从参考手册中获取详细信息真的很难,而且我没有找到关于这个主题的SPC56EL的任何应用笔记。 在DMA_MUX部分,我看到了使用eTimer模块作为DMA源的可能性。表173显示了eTimer_0的两个源 - Channel0和Channel1。但是,这是什么意思?什么样的请求将eTimer连接到DMA?它们是关于捕获和比较寄存器的吗?我如何将eTimer与DMA结合使用? 我想要做的是在eTimer生成比较事件时触发数组元素的传输。 eTimer应该从比较加载寄存器重新加载新的比较值,然后由DMA更新。 最好的祝福, 帕特里克 以上来自于谷歌翻译 以下为原文 Hello, I have found the problem. I think it was a combination of wrong channel config and DMA_MUX config. The following code gives me a continuous transfer of the array elements to the PGPDO port. The DAC2Table contains 128 16bit elemements.
I was also able to trigger the transfer of an array element using PIT and the triggered functionality. Nevertheless, I have again some problems in understanding how to use DMA with other modules. It is really hard to get detailed information out of the reference manual and I didn´t found any application notes for the SPC56EL regarding this topic. In DMA_MUX section, I saw the possibility to use the eTimer module as DMA source. Table 173 shows two sources for eTimer_0 - Channel0 and Channel1. But what does this mean? What kind of request connects the eTimer to DMA? Are they regarding to the capture and compare registers? And how do I use the eTimer in combination with DMA? What I want to do is to trigger the transfer of an array element when the eTimer produces a compare event. The eTimer should reload the load the new compare value from the compare load register, which should then be updated by DMA. Best regards, Patrik |
2776 浏览 1 评论
3251 浏览 1 评论
1822 浏览 1 评论
3667 浏览 6 评论
6060 浏览 21 评论
1347浏览 4评论
212浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
372浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
464浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
291浏览 2评论
GMT+8, 2025-1-9 01:40 , Processed in 1.029087 second(s), Total 75, Slave 59 queries .
